O rings for fork air balance tube
- RBY
- Junior Member
1 year 2 months ago
Hi, does anyone have the correct size measurments for the O rings (4) that seal the air balance tube on the front forks. OEM part is 92055-1106 but can't find anywhere but likely available at local seal and O ring shop if I have the correct sizing. Thanks
- kawaBCN
Re: O rings for fork air balance tube
1 year 2 months agoEBAYHi, does anyone have the correct size measurments for the O rings (4) that seal the air balance tube on the front forks. OEM part is 92055-1106 but can't find anywhere but likely available at local seal and O ring shop if I have the correct sizing. Thanks
RUN LIKE THE WIND¡¡¡
- RBY
- Junior Member
1 year 2 months ago
Thanks, I did see that one but not very keen to spend GBP27 plus freight for half way around the world to get one O ring. If no one has measurements I guess I may just have to do that.
- RBY
- Junior Member
1 year 1 month ago
Well I shouldn't have been so lazy. Whipped out the old ones and down to the local seal shop. 40 x 3.5mm NBR 70. Bought eight for $6. Popped in and work like new.
Replaced fork oil and tip for the weary - Service Manual on page 226 has "about 360cc" but my bike is an A5 and the Supplement for the 1983 model, page 368, indicates 409+/-4ml !!
The following user(s) said Thank You: dcarver220b, stocktoy, Kawboy
- dcarver220b
1 year 1 month agoPlease Log in or Create an account to join the conversation.
Time to create page: 0.158 seconds
