kz1300 banner
Steering bearings.
  • Richobob
  • Richobob's Avatar Topic Author
  • New Member
  • New Member
Steering bearings.
3 weeks 3 hours ago
#34803
Any suggestions for replacement steering bearings in the UK for my 1980 A2 please?
  • dcarver220b
  • dcarver220b's Avatar
Re: Steering bearings.
3 weeks 2 hours ago
#34805
You might try AllBalls bearings...
I'm not a big fan of AB bearings... but tapered is the way to go, and they are available.
With a bit of searching, you might find higher quality FAG or Timkens...
Then again, steering head bearings are under-stressed, not worked hard, and the AB bearings price point is good too.
The key is tapered bearing, not ball bearings.
After years of service, ball bearing will make indents into the races, causing a 'notchy' feeling.
Good luck!
d
  • scotch
  • scotch's Avatar
2 weeks 6 days ago
#34806
I took the bearings to a local auto-parts store where they matched the #'s and provided me with the bearings needed.
Always High - Know Fear !
  • stocktoy
  • stocktoy's Avatar
2 weeks 5 days ago - 2 weeks 5 days ago
#34808
And don't forget the seals some replacement bearings don't come seals and will let all kinds of crud settle in on the bearings causing problems
Last edit: 2 weeks 5 days ago by stocktoy. Reason: spelling
  • dcarver220b
2 weeks 5 days ago
#34809
Great add to the post stocktoy!
Time to create page: 0.154 seconds
