kz1300 banner
Welcome to the Kunena forum!
please help ive got a ????on the cylinders
  • bobber-edd
  • bobber-edd's Avatar Topic Author
  • Premium Member
  • Premium Member
10 years 10 months ago
#7852
ive just rebuilt the whole engine and have found some o rings .................please tell me that they dont go on the cylinders and i have to strip it down again ???????????
zed 13 1979 A1 model
  • zed_thirteen
  • zed_thirteen's Avatar
Re: please help ive got a ????on the cylinders
#7853
It depends?
If they are bore sized 'O' rings then they will be for the cylinder sleeves. If you haven't taken them out then I wouldn't bother. I think the manual says if you leave the block standing on the bottom of the sleeves then gravity will push the sleeves out of the block - I have not been able to remove them when using my own non-destructive force and have never gone to the trouble of getting the sleeves pressed out to change the seals.
However, if they are 4 small 'O' rings (around 12-13mm) then yes, they are important. They will be the ones that seal the oil passageways between the crank case and the base of the block - I forgot to put these in myself once!
1980 KZ1300 B2 Touring/A2
1980 CBX1000-A
1990 ZZ-R1100 C1
The following user(s) said Thank You: KZQ, bobber-edd
  • bobber-edd
  • Premium Member
  • Premium Member
#7854
they are the same size as the bores ??and theres about 12 of them in the pack ihope i dont need them as i never took anything out
  • Tyler
  • Tyler's Avatar
  • Elite Member
  • Elite Member
#7859
No you don't, those large O-rings are for the sleeves. If you didn't push the sleeves out of the block, you don't need them.
1981 KZ1300
The following user(s) said Thank You: bobber-edd
Time to create page: 0.161 seconds
