kz1300 banner
Welcome to the Kunena forum!
Oregon motorcycle Parts vrrpm3 rectifier wiring
  • rdbhere2
  • rdbhere2's Avatar Topic Author
  • Elite Member
  • Elite Member
10 years 9 months ago - 10 years 9 months ago
#8288
Anyone know why this rectifier/ regulator doesn't have a brown wire or yellow wire?
Last edit: 10 years 9 months ago by rdbhere2.
  • tackelhappy
  • tackelhappy's Avatar
Re: Oregon motorcycle Parts vrrpm3 rectifier wiring
#8311
All the power from the regulator/rectifier goes to the battery.
On the oem setup, the brown wire would feed power directly to parts like the defunct fuel valve.
Or to relays to the turn signals.
As the rectifier is not bike specific, I can only assume putting all the power to the battery was how most bikes were in the day.
OKANAGAN FALLS. BC ,Canada
The following user(s) said Thank You: rdbhere2
  • rdbhere2
  • Elite Member
  • Elite Member
#8313
ok so the vrrpm3 rectifier/regulator isn't made with a brown wire to feed components such as relays and fuel solenoid on kz1300's because the power is taken from the ignition switch. The vrrpm3 doesn't have the 4th yellow wire so I have to splice into one of my stator yellow wires to power the temp and fuel gauges. Thanks for the info Tony. ( Oregon Motorcycle Parts. )
Time to create page: 0.153 seconds
