kz1300 banner
Welcome to the Kunena forum!
Oil light on
  • rdbhere2
  • rdbhere2's Avatar Topic Author
  • Elite Member
  • Elite Member
Oil light on
10 years 6 months ago
#9489
Oil light cse on and the bike has oil
Will temperature cause this light to cum on after a long ride or...
  • rdbhere2
  • Elite Member
  • Elite Member
Re: Oil light on
#9490
Just put a quart of oil in the crankcase and the oil light went out. The oil level didn't look that low on the sight glass. 100 miles from home on a 35 year old bike with an oil light on will make your heart skip.
  • McZed
  • McZed's Avatar
  • Elite Member
  • Elite Member
Re: Oil light on
10 years 6 months ago - 10 years 6 months ago
#9491
I always fill mine up to nearer the top of the sight glass, a bit above the upper level line.
Z1300 UK
Last edit: 10 years 6 months ago by McZed.
The following user(s) said Thank You: rdbhere2
  • rdbhere2
  • Elite Member
  • Elite Member
Re: Oil light on
#9492
As soon as the oil light came on my bike shut off. I waited a minute and checked the oil level and it seemed ok but I guess this oil sensor likes the upper hash mark level. Anyway the light has been off ever since I added a quart. Strange.
  • Kawboy
  • Kawboy's Avatar
Re: Oil light on
#9493
rdbhere2 wrote: As soon as the oil light came on my bike shut off. I waited a minute and checked the oil level and it seemed ok but I guess this oil sensor likes the upper hash mark level. Anyway the light has been off ever since I added a quart. Strange.
The oil light is not a oil level light. It indicates no oil pressure and you should immediately shut the engine off and figure out the problem. No oil pressure and you'll wipe the crank and connecting rod bearings in less than a minute. The other area which requires constant oil pressure is the camshaft bearing surfaces which is the cylinder head itself. Never run with no oil pressure. A couple of seconds on start up, OK. never more than that.
  • aus_z1300
  • aus_z1300's Avatar
  • Elite Member
  • Elite Member
Re: Oil light on
#9494
kawboy mine has the level and pressure on the same light.
Time to create page: 0.193 seconds
