Welcome to the Kunena forum!
Headlight indicator light is very dim
- rdbhere2
- Elite Member
10 years 5 months ago - 10 years 5 months ago
Can hardly see the headlight indicator light. Is this common on kz130 series?
Last edit: 10 years 5 months ago by rdbhere2.
- Lucien-Harpress
Re: Headlight indicator light is very dim
Is the the high beam idiot light? If so, yeah, you usually can't see it too well, unless it's actually dark out. I've got several bikes that are like that, and it's perfectly normal. Mostly due to the dark blue lens filter, I think.
- rdbhere2
- Elite Member
The blue high beam light works fine but the low beam indicator light is barely visible.
- roadhazard
- Junior Member
If you are talking about the light on the far right of the dash which is sort of white in color,that's not a low beam indicator.It's a safety light which tells you that your headlight bulb is burned out. It's on very dim all the time but if the headlight bulb blows out it comes on bright.
1980 Kz 1300 b2 touring
1980 kz 1300 A2
1980 kz 1300 A2
The following user(s) said Thank You: rdbhere2
- scotch
Check the bulbs! Old bulbs can develop a "silvering" on the inside of the globe from years of burning. I'm guessing it's ionized filament. A couple of mine were so bad I could barely see the filament.
I changed to all LED but this required some mods to the LEDs to shorten them to make them fit. It's written up in the forum somewhere.
Always High - Know Fear !
