kz1300 banner
Welcome to the Kunena forum!
Won't run. Help!
  • McZed
  • McZed's Avatar Topic Author
  • Elite Member
  • Elite Member
Won't run. Help!
10 years 2 months ago
#11169
Hi Guys, I’m looking for some advice. I started the big Z up after the long winter lay up. It starts and runs with the choke about half way on, but it won’t rev, open the throttle and it just cuts out. When it warms up it also cuts out and won’t run till its cold again. I put fresh fuel in it so I have eliminated the stale fuel issue. It was running fine before I laid it up for the winter, any advice greatly appreciated. :(
Z1300 UK
  • KZQ
  • KZQ's Avatar
  • Administrator
  • Administrator
  • Lifelong Rider Suffering Through MBD
Re: Won't run. Help!
#11170
Does your fuel have alcohol in it? Were the carbs run dry before you put it up?
Bill
The following user(s) said Thank You: McZed
  • strate6
  • strate6's Avatar
  • On An Adventure Before Dementia ! !
#11173
Tyr these measures below ONE AT A TIME so you know what solved the issue.
Remove plugs, claen and gap them.
Set the gap a little smaller then the manual states as the standard coils are very weak.
Try it .
Next remove air filter.
Try it.
Let us know how you get on from here
Pete F
  • rickster
  • rickster's Avatar
  • Junior Member
  • Junior Member
#11176
You could try removing the drain screws then squirting carb cleaner in to the bowls to dissolve the gum left by the old fuel then flush out bowls with fresh fuel then try and restart failing that it could be carbs out and cleaned time
  • 6cylinder
  • 6cylinder's Avatar
  • Premium Member
  • Premium Member
#11177
carbs are blocked from setting and drying out.. sorry I have fixed that problem to many times on bikes that came out of storage,,
millers auto electric
  • scotch
  • scotch's Avatar
#11178
Always High - Know Fear !
Time to create page: 0.162 seconds
