Welcome to the Kunena forum!
Oil pressure switch - can it be cleaned / fixed??
- hillsy
9 years 11 months ago
Hi guys - my oil pressure switch is not working on my A5 (oil light does not come on, but does if I ground the lead off the switch).
Is the switch mechanical? Looking at pics of used ones on eBay it looks like there is a port / hole for the oil to go into the switch. Is it possible it's just gunked up and can be fixed with a clean??
- hillsy
Re: Oil pressure switch - can it be cleaned / fixed??
Oh - also - are there other switches from other models that can be used instead of the 1300 ones?
- RickG
I have used carb cleaner and let it soak for an hour or so and then wash it out with more carb cleaner and all was good
Z1300 A1 x 2
Z1300 A1 x 2
- hillsy
OK cool - I'll give that a try. Thanks....
- hillsy
9 years 10 months ago - 9 years 10 months ago
Well, all efforts to revive this one have failed.
So, after a bit of Googling it seems they are pretty generic.....so I took it down to my local auto store and he matched it up to one of these:
Except he only charged me $15.
I had to change the connector but it bolted right up and we're good to go again. Lights up with the key on and turns off when you start it....so I call that a win
Code:
http://www.ebay.com.au/itm/Fuelmiser-Switch-Oil-Pressure-Warning-Light-CPS24-fits-Mazda-RX-2-Rotary-Coupe-/151632503761
Last edit: 9 years 10 months ago by hillsy.
- Kawboy
9 years 10 months agohillsy wrote: Well, all efforts to revive this one have failed.
Code:http://www.ebay.com.au/itm/Fuelmiser-Switch-Oil-Pressure-Warning-Light-CPS24-fits-Mazda-RX-2-Rotary-Coupe-/151632503761
Glad to hear you're a winner. Did you go out and buy a lottery ticket?? Not everyone gets that lucky around here.
Time to create page: 0.153 seconds
