kz1300 banner
Welcome to the Kunena forum!
Oil pressure switch - can it be cleaned / fixed??
  • RickG
  • RickG's Avatar
Re: Oil pressure switch - can it be cleaned / fixed??
9 years 10 months ago
#12659
What size is the thread because it looks mighty like it will be a replacement for the K series BMW as well
Z1300 A1 x 2
  • hillsy
  • hillsy's Avatar Topic Author
  • Premium Member
  • Premium Member
#12662
Its M10 size thread, 0.9 pitch.
The switch thread is tapered so it "snugs" into the crankcase when it is tightened.
There's a bunch of different ones available once you start looking - main differences are the connector types and the pressure to activate. This one is 20KPA, there's 40, 50 also but I thought I'd go for the lower one as the max oil pressure on the 1300 is pretty low at around 28PSI.
  • RickG
  • RickG's Avatar
#12664
Ah well no luck there, I need a 12m x 1mm parallel thread and it is prooving very hard to find except for OEM which cost 3 arms.
Z1300 A1 x 2
  • hillsy
  • Premium Member
  • Premium Member
9 years 10 months ago - 9 years 10 months ago
#12699
OK - so I said earlier that all attempts to revive the original switch had failed. Well, here's why:
Yep - looks like my bro thought it would be a good idea to remove it with a chisel at some point. Apparently, they don't like that :blink:
Anyway, here's the new one in it's place:
Works fine and for $15 it was a no brainer. Case closed ;)
Last edit: 9 years 10 months ago by hillsy.
  • Kawboy
  • Kawboy's Avatar
#12704
You'd probably appreciate it if you put a 2" sleeve of waterproof heat shrink tubing over that new connection on the wire. it will save you having to figure out "what happened" a year from now when the oil pressure light won't come on.
Glad to hear you found a substitute oil pressure switch AND that you researched the switch and know at what pressure it comes on and off at. Well done!!
  • Tyler
  • Tyler's Avatar
  • Elite Member
  • Elite Member
#12708
20 KPa is less than 3 psi, but if you loose the pump or run the oil low it would be essentially zero oil pressure.
1981 KZ1300
Time to create page: 0.154 seconds
