kz1300 banner
Welcome to the Kunena forum!
air system leaking down
  • robert78.5
  • robert78.5's Avatar Topic Author
  • New Member
  • New Member
9 years 10 months ago
#13075
1983 ZN1300, the air builds up in front and rear shocks good, but they leak down in about 30 minutes, i soaped all lines and can not see any bubbles, this has me baffled as both front and rear loose air. The manual says to check bleed air valve. I have searched and can not find the pull string to pull. Any ideas where it might be?
  • KZQ
  • KZQ's Avatar
  • Administrator
  • Administrator
  • Lifelong Rider Suffering Through MBD
Re: air system leaking down
#13077
I believe they're referring to the schrader valves. "Pull String"?
Bill
  • robert78.5
  • New Member
  • New Member
9 years 10 months ago - 9 years 10 months ago
#13080
yes, the bleed down valve, can not see the pull ring anywhere. Is it hidden ? also if this is leaking would it cause both front and rear shocks to lose air pressure?
Last edit: 9 years 10 months ago by robert78.5.
Time to create page: 0.167 seconds
