Welcome to the Kunena forum!
Oil light
- Scorpio2016
- Senior Member
Oil light
9 years 9 months ago
If I start the bike after it sits for a while on the side stand the oil light will stay on. But if I shut it off and restart it the light goes out like it should. I just changed the oil and filter and level is correct. Could this be an electrical issue?
- zed_thirteen
Re: Oil light
Does your model have the unreliable oil level switch? Not sure how it works but it also illuminated the low oil pressure red idiot light.
1980 KZ1300 B2 Touring/A2
1980 CBX1000-A
1990 ZZ-R1100 C1
1980 CBX1000-A
1990 ZZ-R1100 C1
- Scorpio2016
- Senior Member
- z13phil
Re: Oil light
I've had this problem so just fitted a 80psi pressure gauge with hose to the pressure switch outlet. Well within workshop manual tolerances. So it's a faulty pressure switch.
- hillsy
Re: Oil light
9 years 9 months ago - 9 years 9 months ago
My oil pressure switch wasn't working so I changed it out for a car one.
I know this is pretty much the opposite of what is happening with you, but they are cheap enough to replace in case it's also your problem.
Thread is over here: www.kz1300.com/index.php/forum/welcome-m...-it-be-cleaned-fixed
Last edit: 9 years 9 months ago by hillsy.
- Scorpio2016
- Senior Member
Re: Oil light
I will be checking into the car pressure switch if cleaning it with carb cleaner doesn't do the trick. Many thanks for the heads up.
Time to create page: 0.165 seconds
