Welcome to the Kunena forum!
no spark on 1 & 6
- Reid
- Junior Member
no spark on 1 & 6
11 years 9 months ago
Just got my 1980 kz1300 and tried to fire it up. Nothing on 1 & 6. Changed out my coil from my 84 GPz550 same thing, nothing. Anyone got any info for me to try. 2,3,4,&5 are good. lots of spark on those one's. Lot's of work, please summer is coming soon and would like to ride it soon, Thanks. Reid
- Mikez
- Elite Member
Re: no spark on 1 & 6
Going to need more info on what you've checked as far as troubleshooting so far. Check your plug condition and might be a good id to get a multimeter and start testing everything to figure out where the connection isn't getting made. Check the ohm in the coil, if it's making contact to ground and what the resistance values are, if it has a solid connection to the igniter etc. Does the bike still have ballast resistor? Are the coils on the bike original? Also check the plug connections for any corrosion.
Hope this helps in getting you started
- zed_thirteen
Might be one of the pick-up coils in the ignition housing. I can't remember how standard coils are connected but it might be possible to temporarily swap the inputs to 2 coils and see if the fault moves.
1980 KZ1300 B2 Touring/A2
1980 CBX1000-A
1990 ZZ-R1100 C1
1980 CBX1000-A
1990 ZZ-R1100 C1
- Toddh
11 years 9 months ago - 11 years 9 months ago
Ditto on what MikeZ states above:
If it does come down to pick up coils, remember they can check ok while cold, but they can fail at normal engine operating temperature.
Had that scenario happen last summer on my KZ1000. Bike would run great while cold, then 1/2 hour later, crappy ignition.
But if your 1/6 cylinders are not firing when cold I would start with the high tension side first, then work your way into the low voltage side.
High Tension side:
Ohm out coils, high and low side. Intermittent, loose, or corroded connectors. Ohm out the resistor caps. Plugs fouled?
Low Voltage Side:
Main harness connections for 1/6 coil down to the Ignitor. Ohm out the Pickup Coils, then the harness from the Pickup Coils to the Ignitor.
I would suspect the high tension side first.
Regards.
T.
High Tension side:
Low Voltage Side:
Regards.
T.
KZ1300 A-4 4TH 1300 IN 30 YEARS
KZ1000 D-3/ Z1R
ZX900 GPZ A-3
KZ750 E-1
K1200GT
CB750F 1978
KZ1000 D-3/ Z1R
ZX900 GPZ A-3
KZ750 E-1
K1200GT
CB750F 1978
Last edit: 11 years 9 months ago by Toddh.
- CoffeeBear
- Junior Member
Just a suggestion, but you could swap signal wires from another coil pack to see if the coil will fire, this would at least be a sure way of determining the control signal is the culprit.
- Reid
- Junior Member
Thanks for all the advice,turns out the ground wire (blk) for the 1 & 6 coil was broken. Attached it to another ground and all good now. Spark on all 6 plugs.
Time to create page: 0.175 seconds
