Welcome to the Kunena forum!
no spark on 1 & 6
- Toddh
Re: no spark on 1 & 6
11 years 9 months ago
Gotta love those easy fixes.
Todd.
Todd.
KZ1300 A-4 4TH 1300 IN 30 YEARS
KZ1000 D-3/ Z1R
ZX900 GPZ A-3
KZ750 E-1
K1200GT
CB750F 1978
KZ1000 D-3/ Z1R
ZX900 GPZ A-3
KZ750 E-1
K1200GT
CB750F 1978
- Reid
- Junior Member
Another problem, got spark on 1 & 6 but will not fire up the in the cylinder, both pipes are cold but the other 4 get hot. Anyone got the firing order and what colour wires go to which coil. I think the previous owner might have gotten the wires mixed up. Thanks, Reid
- wrgoo56
- Reid
- Junior Member
Yes 1 & 6 are blk, 2 & 5 are grn and 3&4 are blue. When I connect the blk with the blk in the wiring harness I get nothing, when I connect the blk from the coil to grn or blue I get spark. I then screw in the plug and connect the blk to grn or blue I get no firing from cylinders 1 & 6, just wet plugs, but they spark outside the cylinder. Any help would be appreciated. Thanks Reid.
- zed_thirteen
It's not going to fire if your black HT coil is connected to either the green or blue pickups because the spark timing will be incorrect for 1 and 6.
You have established that it is not your HT coil so it must be either one of the ignition pickups or the ignitor.
1980 KZ1300 B2 Touring/A2
1980 CBX1000-A
1990 ZZ-R1100 C1
1980 CBX1000-A
1990 ZZ-R1100 C1
- strate6
- On An Adventure Before Dementia ! !
11 years 9 months ago - 11 years 9 months ago
If the plugs spark OUTSIDE of the cylinder, then they will spark inside.
This maybe too much fuel (flooding) from the carbs rather than an electrical issue, especially if the plugs are wet ??
Alternatively you may have valve problems letting compression out ?????
Pete F
UK
Pete F
UK
Last edit: 11 years 9 months ago by strate6.
Time to create page: 0.161 seconds
