Welcome to the Kunena forum!
starting problem
- kwit1961
- New Member
starting problem
11 years 11 months ago
i got my 80 kz 1300 touring out today and it barely turned over so since the battery was 5 years old and froze a few times i went and got a new one and fully charged still turns over about twice then nothing i put charger on it and same thing could starter be junk and how much of a pain to get it off and test it? thanks for any info
- Toddh
Re: starting problem
Hello Kwit and welcome to the forum.
Based on your description, a couple of items come to mind.
1: I would take the spark plugs out and rotate the engine over by hand to make sure there is no binding occurring, or drag. (Consult the shop manual on how to do this)
2: Take a volt meter to the starter contactor (Low voltage side/ small wires) and make sure you are getting all 12 volts to the starter. This will test the starting circuit from your new battery, main harness, starter button, down to the contactor. Make sure the large conductor from the starter contactor to the starter is tight and not corroded.
3: The starter is fairly easy to remove, again consult the shop manual. Take the starter to a local auto electrical shop for a starter draw test. If it draws too many amps, they can refurbish the starter for you for a relatively low cost. (New bushings, and cleaning up the armature.) Our starters are fairly trouble free and rarely fail.
It's possible you could have a bad starter but I would suspect that last.
Hope this helps, keep us posted.
Todd.
Todd.
KZ1300 A-4 4TH 1300 IN 30 YEARS
KZ1000 D-3/ Z1R
ZX900 GPZ A-3
KZ750 E-1
K1200GT
CB750F 1978
KZ1000 D-3/ Z1R
ZX900 GPZ A-3
KZ750 E-1
K1200GT
CB750F 1978
- RickG
I would be looking for a corroded terminal on the battery, solenoid or starter.
A corroded terminal will conduct when cold but not very well and when you hit the starter button the terminal is subject to high current which makes it heat up and then it stops conducting at all.
Z1300 A1 x 2
Z1300 A1 x 2
Time to create page: 0.164 seconds
