Welcome to the Kunena forum!
Water pump woes
- Torque59
- POTEST ALITER SUBVENIRI NON POTEST PRO CUBICUS
Water pump woes
11 years 7 months ago
Hi everyone,
Got a mechanical seal and oil sesl for my A4 1300. Have got the pump cover off and am now trying to get the impeller off the shaft. Doesn't seem to want to budge.
Any suggestions.
Thanks.
Any suggestions.
Thanks.
Restored an 1976 Suzuki GT550B
Restored an 1982 Kawasaki Z1300 A4.
Also rides a 2014 Triumph Rocket Roadster, 2300cc of pure fun.
- zed_thirteen
Re: Water pump woes
once the circlip has been removed there is only an 'O' ring between the shaft and the impeller.
I think some sort of corrosion occurs between the steel and aluminium which can make them very hard to get off and there isn't room to get any kind of puller behind the impeller.
Once you get the impeller of there are two bolts to remove from the mechanical seal. I think there are then two threaded holes where you can carefully use bolts to separate it from the block
1980 KZ1300 B2 Touring/A2
1980 CBX1000-A
1990 ZZ-R1100 C1
1980 CBX1000-A
1990 ZZ-R1100 C1
- strate6
- On An Adventure Before Dementia ! !
Re: Water pump woes
As ever, zed-thirteen is bang on the money !!
Nothing to add really other than BE CAREFUL how you treat the impeller shaft, as the other end has a METAL driven gear on it...........that is DRIVEN by a Nylon Gear that is not the best design or strongest component inside a 1300 motor !!
Treat it like a lady............!
Pete F
UK
Pete F
UK
Time to create page: 0.156 seconds
