kz1300 banner
Welcome to the Kunena forum!
Battery ground cable ?
  • kennyb
  • kennyb's Avatar Topic Author
11 years 5 months ago - 11 years 5 months ago
#4176
I can't remember were this cable was connected. I think it's a ground? Can can some one direct me to where it goes?Thank you
Last edit: 11 years 5 months ago by kennyb.
  • bobber-edd
  • bobber-edd's Avatar
  • Premium Member
  • Premium Member
Re: Battery ground cable ?
#4180
hi it fits on the back off the motor any of the bolts but sort of under the battery but on the engine casing cheers
zed 13 1979 A1 model
The following user(s) said Thank You: kennyb
  • kennyb
#4182
There already is a ground wire coming off the back of the motor.This particular wire seem a bit too short to reach. Any one can share some detailed pics of that area it would be greatly appreciated,thanks.
  • kza13
  • kza13's Avatar
#4185
Think it goes from the battery to the starter relay, positive power, then a cable from the other side of the starter relay goes down to the starter motor
Frame No: KZT3OA003911
Engine No: KZT3OAE004153
Last edit: 11 years 5 months ago by kza13.
  • kennyb
#4190
No there is a positive already going from the Batt to the relay and then the starter motor. The bike powers up seems to be functioning so far. I still haven't started it. Hopefully when I get to that point every thing should work.Any one else want to take a shot at this?
  • Toddh
  • Toddh's Avatar
#4192
Kenny:
You are correct about the positive terminals being tied to the starter relay.
On my A-4 the negative battery lead runs from the - post from the battery to the back of the engine case. Near and under the RH side cover.
Like you indicate it's a short lead.
KZ1300 A-4 4TH 1300 IN 30 YEARS
KZ1000 D-3/ Z1R
ZX900 GPZ A-3
KZ750 E-1
K1200GT
CB750F 1978
Time to create page: 0.171 seconds
