Progress so far.
- mizztheman
- Elite Member
Progress so far.
8 years 6 months ago - 8 years 6 months ago
Hi Gents,
Been a while since I posted progress on the bike but here’s a few photos of where I’m up to so far.
Last edit: 8 years 6 months ago by mizztheman.
- Kawboy
Re: Progress so far.
Looking pretty good there. I'm liking where it's going. She's going to be a beauty.
The following user(s) said Thank You: mizztheman
- StanG
- Banned
Looking good! I have a couple questions.
Regarding paint - did you use primer? Did you heat treat the paint after painting? I had problems with VHT paint, but I don't have a place to heat treat. The recommended 400 F is way too much anyway for seals etc. Mine was matte though.
Another one: the spark plus boots. 2 shorter ones and 4 longer? Where did you get them?
Stan
Stan
- biltonjim
Very nice. have you had the engine stripped down? And the frame - is it powder coated?
- Tonto
Martin, that looks great mate: top job.
I do like shiny, and that looks absolutely spot on.
Cheers Tim
Cheers Tim
- mizztheman
- Elite Member
Thanks for all the comments.
I only took off the crankcase covers, sump and cam cover box off the engine after painting. These covers were masked off first. The engine was out of the frame, degreased and then sanded with scotchbrite pads. Degreased again then painted. The bike has been totally stripped back to the frame and the frame has been powder coated. You’ll notice that the fairing brackets have been removed as these wasn’t present on UK bikes. All the crankcase covers have been rechromed and nuts and bolts have been zinc/nickel plated
Stan, I’ve put links to the website where I bought the plug caps and a link to the website for the paint. I didn’t use a primer as if I remember correctly they only recommend a primer on bare metal.
I’ll cure the paint by using the heat of the engine once I get it started as the paint is touch dry after 30 minutes and doesn’t rub off like some other VHT paints.
www.gsparkplug.com/1x-ngk-resistor-spark...-xb05f-red-8592.html
www.gsparkplug.com/1x-ngk-resistor-spark...-yb05f-red-8162.html
www.vhtpaint.com/high-heat/vht-engine-enamel
Moderators: dcarver220b
Time to create page: 0.174 seconds
