kz1300 banner
Carb float level bowl drain check
  • scotch
  • scotch's Avatar
Re: Carb float level bowl drain check
7 years 9 months ago - 7 years 9 months ago
#20452
"And let the measurement of the fire-liquid within the first chalice be henceforth measured from The Lip. Let not the measurement be seen from elsewhere but from that only of The Lip. And the Measurement from The Lip shall be that of 7.5. Let not this Measurement be that as to exceed a measure of 8.5 nor shall Ye allow the measure to be less than 6.5. Whence one witnesses within the first chalice the divine measurement that of 7.5 allow only this measurement to procreate from The Lip of the second and third and then and only then ride forth in the glory of the harmony and unity of the chalices three."
From the Holy Book of Scotch "Proofs: 1:40" :evil:
Sorry "Monty" fans ! Couldn't resist...........cuz we all know THAT"S Futile !
Always High - Know Fear !
Last edit: 7 years 9 months ago by scotch.
The following user(s) said Thank You: zed_thirteen, DannyKZ, Daro
  • StanG
  • StanG's Avatar
  • Banned
  • Banned
#20454
That's what she said!
  • Daro
  • Daro's Avatar
  • Premium Member
  • Premium Member
#20455
Ha ha ha !!! Scotch, this must be by far the best quote on entire kz1300 platform. Thank you !
  • scotch
  • scotch's Avatar
#20459
What ever helps you remember !!! :woohoo:
  • StanG
  • StanG's Avatar
  • Banned
  • Banned
#20460
Problem now is I might never forget it! hahaha Just need a camp fire and talk about 'when I was young, tadada.da... in thirty years
Last edit: 7 years 9 months ago by StanG.
  • RChaloner
  • RChaloner's Avatar
  • Elite Member
  • Elite Member
#20466
I hate to have to comment on this, as I'm sure you more experienced guys have heard this discussion toooo often, but as some of us are still on our first carb assembly iteration..
Stans' vernier pictured is indeed in the right place, is it not?
The manual says to measure form the bottom of the carb body, which is the machined flange surface, and as you quite logically say Scotch, that is the only (or the most convenient externally at least) reference surface relative to the jets, whereas other parts of the bowl outer dimensions should be assumed to be variable, depending on casting type, gasket age etc.
So when you say for Stan to move his vernier, can you confirm you do advise measuring 6.5 - 8.5mm from the machined flange as per the manual, or are you saying that's been superseded by a different or better practice?
(the reason for asking is of course that the flange at the top of the bowl, if one were to measure from it's lower outer surface, is another 4 or 5 mm so a massive variance)
Sorry guys, hope I'm not flogging an excessively dead horse here...
Richard.
1979 KZ1300 A1
1999 K1200LT - now sold, I like them however was nearly as big as my X5 but no faster.
Moderators: scotch
Time to create page: 0.157 seconds
