Choke Air mod
- Frank833
- Elite Member
Re: Choke Air mod
7 years 4 months ago
I've seen lots of old discussions on the "Choke Mod", but these are the first pictures I've seen that make it clear what hole is being talked about - I had deduced this was the hole, but these pictures make it clear. I've also not seen a clear explanation for the reason for the mod (though I have seen a number of folks saying it works well).
Is this mod restricting air to the engine, or getting the enrichment circuit to pull in more fuel?
In what kind of air temperatures is this mod most beneficial?
- strate6
Re: Choke Air mod
Hi,
Coming in on the end of this post, can someone please advise what the purpose of this mod is for ?
Thanks
Pete F
UK
Thanks
Pete F
UK
- bluefan44
- Junior Member
Re: Choke Air mod
7 years 4 months ago - 7 years 4 months ago
www.kz1300.com/index.php/forum/carburato...-start-issue?start=0
In this thread Scotch theorizes that this port being reduced in size will allow the engine to start better by partly blocking this port you increase the vacuum in the carbs letting the bike start easier. I wish we had a before and after video for this mod.
Last edit: 7 years 4 months ago by bluefan44.
- zed_thirteen
Re: Choke Air mod
I broke three drill bits trying to drill MIG tips so I've ordered some of the 280 jets that were recommended
1980 KZ1300 B2 Touring/A2
1980 CBX1000-A
1990 ZZ-R1100 C1
1980 CBX1000-A
1990 ZZ-R1100 C1
- Frank833
- Elite Member
Re: Choke Air mod
I did the rivet body method. Granted it does not "look as professional", but no mods to the carbs and with epoxy holding them in I can remove them with a bit of heat. Chances are, no one will see them until I'm dead or too old to ride.
Plus, I had the rivets and epoxy on hand so took all of 5 minutes when the carbs were on the bench anyway.
- scotch
Re: Choke Air mod
zed thirteen wrote: "I broke three drill bits trying to drill MIG tips......"
MIG tips are a hard Brass. Best done on a drill-press so the feed can be controlled. No need to drill the entire tip 3/32". They can be first counter-bored with a more robust 1/8" drill - then use the 3/32" to complete the drilling.
Note: The MIG tip MUST be shortened as shown in the photos of one of the original posts !
My "Holley" jets should be here in the next day or two, and will post.
Always High - Know Fear !
Moderators: scotch
Time to create page: 0.175 seconds
