kz1300 banner
Correct Fuel Line Routing
  • KZQ
  • KZQ's Avatar
  • Away
  • Administrator
  • Administrator
Re: Correct Fuel Line Routing
12 years 3 months ago
#2511
zed_thirteen wrote: Very helpful Pete.
I fitted a brand new pingel fuel tap and it still leaks fuel when it is off. Might look for one of those GPZ900R fuel taps
That's too bad and very strange. I can think of a few things around my house that I wish would shut off as cleanly as the Pingle I fitted to my 13.
Good Luck
Bill
  • kwak1261
  • kwak1261's Avatar
#2519
KZQ spot on,
I have pingle taps on my Z1260J and my GS1000S and never had a problem
Z1300 A4 ZG1300 DFI X2
Z1261J GS1000S
Vmax1200 XT500
  • strate6
  • strate6's Avatar
#2522
Pingle taps are normally spot on & a quality product.
The only problem is............if you forget to turn them off, you then risk flooding your engine.
This is impossible with the GPZ900 tap........which is why I fitted it.
My memory aint as good as it used to be !
Pete F
  • kza13
  • kza13's Avatar
12 years 3 months ago - 12 years 3 months ago
#2528
When the 13 came out it had an electric solenoid fuel shut off valve
Frame No: KZT3OA003911
Engine No: KZT3OAE004153
Last edit: 12 years 3 months ago by kza13. Reason: i was wrong again
  • KEL
  • KEL's Avatar
  • Senior Member
  • Senior Member
#2529
I just looked at mine and it is mounted to the frame ABOVE the carbs.
(see the picture. its the small box thingy)
Aftermarket??
[IMG
Last edit: 12 years 3 months ago by KEL.
  • scotch
  • scotch's Avatar
12 years 3 months ago - 11 years 1 month ago
#2537
reference material out dated and no longer relevant
Always High - Know Fear !
Last edit: 11 years 1 month ago by scotch.
Moderators: scotch
Time to create page: 0.174 seconds
