Correct Fuel Line Routing
- Toddh
Re: Correct Fuel Line Routing
12 years 3 months agokza13 wrote: When the 13 came out it had an electric solenoid fuel shut off valve, so the fuel line ran down to it and then back up to the carbs, just thought i'd mention that, I haven't got one of those solenoid valves (I want one), so I just run it over the top of the carbies, I do run the hose between the throttle cables, above the adjustment nuts, so it lines up better with the petcock outlet, also have a small in line filter a short distance from the carby inlet, works good (touch wood)
Attachment not found
kza:
Just to be clear about this photo, the solenoid valve came from the factory with the switch mounted to the air box. (Not mounted to the engine.)
Regards.
Todd.
KZ1300 A-4 4TH 1300 IN 30 YEARS
KZ1000 D-3/ Z1R
ZX900 GPZ A-3
KZ750 E-1
K1200GT
CB750F 1978
KZ1000 D-3/ Z1R
ZX900 GPZ A-3
KZ750 E-1
K1200GT
CB750F 1978
- kza13
12 years 3 months ago - 12 years 3 months ago
Yep your right, page 46 of the manual images E2 and E3
Frame No: KZT3OA003911
Engine No: KZT3OAE004153
Last edit: 12 years 3 months ago by kza13.
- KEL
- Senior Member
12 years 2 months ago
Had a mixed day trying to get this sorted today.
Tried all the ideas and gave up.
I am now looking to get a small elbow fitting to try and get the angle correct at the carb end.
I figure the early post is the go, straight out of the tank, along the gap, hard u turn back to carbs into a right hand fitting to the inlet.
Also found the delightful trait of carb overflowing when tap is on and bike is on the side stand.
What a totally terrible design all round eh!!!
- zed_thirteen
yes, leaving the fuel tap on with the bike on the side stand is a problem.
I know a few owners who get into the habit of turning the fuel tap off just before they arrive somewhere to drain the hose and lower the level in the float bowls
1980 KZ1300 B2 Touring/A2
1980 CBX1000-A
1990 ZZ-R1100 C1
1980 CBX1000-A
1990 ZZ-R1100 C1
- Toddh
12 years 2 months agozed_thirteen wrote: yes, leaving the fuel tap on with the bike on the side stand is a problem.
Totally agree with you ZED.
Shutting off the tap a few hundred feet from the parking spot, at the end of the day does wonders in keeping fuel off of the ground and out of the crankcase.
Also using the center stand is a good preventative measure at keeping the bowls level.
In the mid 90's, I know of an entire Kawasaki/ Harley dealership that burned down to the ground due to a leaking fuel tap off of a KZ1000P. The dealership was a total loss with all of their inventory.
T.
KZ1000 D-3/ Z1R
ZX900 GPZ A-3
KZ750 E-1
K1200GT
CB750F 1978
KZ1000 D-3/ Z1R
ZX900 GPZ A-3
KZ750 E-1
K1200GT
CB750F 1978
- KEL
- Senior Member
Well thanks for all the tips.
I went and bought another meter of new black rubber fuel line. Nice and soft too.
Ran straight out of the tap and across all carbs then into this neat little elbow filter and then under the carbs and up to the T fitting.
Gunna make up a small clamp to hold the filter to the motor but I am really happy with the result.
Gee this was a poor design.
Moderators: scotch
Time to create page: 0.175 seconds
