kz1300 banner
Correct Fuel Line Routing
  • zed_thirteen
  • zed_thirteen's Avatar
Re: Correct Fuel Line Routing
12 years 2 months ago
#2840
Hi Kel,
next time you get chance - the cable from the ignition pickups should come under the housing and along the top of the crankcase.
It will work just fine the way you have it but would probably be more prone to damage and knocks?
1980 KZ1300 B2 Touring/A2
1980 CBX1000-A
1990 ZZ-R1100 C1
  • KEL
  • KEL's Avatar
  • Senior Member
  • Senior Member
#2868
Well thanks for all the tips.
I went and bought another meter of new black rubber fuel line. Nice and soft too.
Ran straight out of the tap and across all carbs then into this neat little elbow filter and then under the carbs and up to the T fitting.
Gunna make up a small clamp to hold the filter to the motor but I am really happy with the result.
Gee this was a poor design.
[IMG
  • slidewayes
  • slidewayes's Avatar
  • Junior Member
  • Junior Member
#2875
this looks like an elect fuel pump above the carbs?
KEL wrote: I just looked at mine and it is mounted to the frame ABOVE the carbs.
(see the picture. its the small box thingy)
Aftermarket??
[IMG
  • Mikez
  • Mikez's Avatar
  • Elite Member
  • Elite Member
#2878
Yep that's a 12v fuel pump you can find them pretty easily on ebay for like 20 bucks :).
Moderators: scotch
Time to create page: 0.194 seconds
