1979 A1 Carb Refurb - Idle Jet Adjustment - not working
- dcarver220b
1979 A1 Carb Refurb and Web site issue
1 year 5 months ago - 1 year 5 months ago
I am sorry to have to link to my blog.. But I can no longer cut and paste from candybutt.org to here after the Kz1300 Joomla upgrade
.. Which I understand, from security perspectives..
But to completely reformat from CBA to KZ1300 is very time consuming.
Not sure what to do here.
Anyway.. I've being reworking my carb rack using Scotch's cleaning tool..
I HATE to cross link.. and no not many will take time or energy to look at my site and post back here.
And I'll continue to work on what I can do to 'transform' from CBA to KZ1300 formats.. but until then..
My journey to learn KZ1300 carbs...
I hope you have patience and will comment back here if what you see I am doing is not right.. or could be done better.
Last edit: 1 year 5 months ago by dcarver220b.
- scotch
Re: 1979 A1 Carb Refurb and Web site issue
1 year 5 months ago
Re: My journey to learn KZ1300 carbs...
A few random comments: Again; good to see you diggin’ in to these carbs !
First and foremost; “These carbs have been worked on by wiredgeorge…..”
*If this is the level of “quality” that George is demonstrating then I’ll say right-up-front,” George needs to retire! Unacceptable/deplorable and disgusting!
Fuel connector (and Tee). I’ve rebuilt carbs where these connectors practically fell out! I clean them with lacquer thinner, use a brass wire tube cleaner to clean the inside then soak them in lacquer thinner for about 30 minutes. This rejuvenates the rubber. Dry and a apply some silicone grease. Never had “an old one” leak!
Pilot-needle springs. Use the originals or those in the kits. Longer ones will prematurely stop the needle from closing and that will affect the “3.5” turns count and therefore the initial mixture setting!
Back to George: Those emulsion tubes have been butchered on a wire-wheel. Emulsion-tube won’t fit? There is corrosion/scale in the tower. Remove with a tube-cleaner.
High-speed needles: I don’t understand the use of the 4th groove AND a “spacer”? 3rd slot always – no spacers! Those shown are from a generic kit sold on eBay. I’ve never had an issue with these kits.
Blasting media debris in Enricher and throttle body * If "He" “blasted” the venturis with the throttle-plates in place the “sharp” edges of the throttle plates will have been “rounded” and that could have detrimental effect on tuning. I've always believed that the precision ground edge and the precise fit, is critical ! I’d be very interested in hearing about how these carbs tune and operate from idle through transition!
Always High - Know Fear !
- dcarver220b
1 year 5 months agoThank you Scotch. Sincerely said.Re: My journey to learn KZ1300 carbs...
Regarding the work of the carburetor rebuilder. Let's just say I should've paid attention to advice on this forum which was to do it myself. I spent over $1400 for a so-called quality job on two racks. I based that experience from the work that Jack Wagner at old school carbs did for my CBX. Those came back, absolutely freaking beautiful and worked on initial install. Exceptional craftsmanship.
I have a question about the emulsion tubes. I cleaned them all up using green scotch bright like I think you saw on my website. Is a seal required between the upper portion of the emulsion tube to ensure proper fuel air mixture?
Regarding the throttle plates, I had the same thought. I looked at them underneath the magnification, and they are still crisp and clean to the best I can tell.
- dcarver220b
Once again, sorry, sorry, but it takes way too much time for this old guy to 'translate' to Joomla.. so I'll link again.
Having said that, if *anyone* wants to take the time to make that translation happen, to where the pics and text can appear directly here, you have my full appreciation.
Ok then, (with apologies to the title, but what the heck, yeah? Nothing like giving kz1300 carbs a good blow job!)
2024-12-30 More Scotch BlowJob
- dcarver220b
Followed by my, oh crap, experience where I launched the needle assembly up to the space station.
2024-12-31 Scotch Blow Job OH SHIT
d
d
- dcarver220b
2025-01-01 Scotch Tool Cleaning Day 3
Hitting the homestretch now.
Another 3 1/2 to 4 hours and all three carbs have been cleaned using the scotch tool, given a blow job with the air compressor at 40 psi.
I still have the problem of the missing needle, spring, and top hat that went for a cruise into space somewhere in in the shop.
I am hoping that the carb kit has these parts, otherwise I will be searching for hours.
My little work area. Old-school stereo upper left-hand corner various old drivers licenses on the wall. Someday he'll become more organized.
As you can see, I have scotches instructions in the bar, right hand corner, and then following it verbatim. Well, actually, it's more like a procedure revision.
2025-01-01 Scotch Tool Cleaning - Day 3
Moderators: scotch
Time to create page: 0.165 seconds
