kz1300 banner
Electrical
Voltage gauge regulator
  • kwak1261
  • kwak1261's Avatar Topic Author
12 years 3 months ago
#2407
I have a problem.
the fuel gauge and the temp gauge are supplied by the same wire from a small regulator on the left side of the head stock.
this device should supply 7 Volts but mine is supplying 11.45 volts
this makes the gauges give false high readings.
does anyone know of a repair or a replacement for this part
ive looked on MCG but cant find one
any ideas
Ian
Z1300 A4 ZG1300 DFI X2
Z1261J GS1000S
Vmax1200 XT500
  • Toddh
  • Toddh's Avatar
Re: Voltage gauge regulator
#2408
No eBay APP ID and/or Cert ID defined in Kunena configurationHere is one listed on Ebay (new) for $119.99, A little higher than list but not too bad.
Or locate a use one.
Regards.
T.
KZ1300 A-4 4TH 1300 IN 30 YEARS
KZ1000 D-3/ Z1R
ZX900 GPZ A-3
KZ750 E-1
K1200GT
CB750F 1978
  • strate6
  • strate6's Avatar
#2421
Ian,
It is a very simple component (voltage reducer) & therefore would be very easy for a decent auto electrician or similar to open up & replace the resistor or component inside that has failed, if you cannot find a used one (look to be expensive too).
As long as you let them know what reading it should be sending out, they should be able to help.
Pete F
  • kwak1261
#2430
Wow good find, thanks Toddh. a bit ambitious with the price, might have to be the last resort
Pete, i was thinking the same way
am de soldering all the components from the board and doing a value test.
its already broken so no loss really
Ian
Z1261J GS1000S
Vmax1200 XT500
  • Toddh
  • Toddh's Avatar
12 years 3 months ago - 12 years 3 months ago
#2433
If you come up with the right parts and availability, it might be a good article to save for the forum.
T.
KZ1000 D-3/ Z1R
ZX900 GPZ A-3
KZ750 E-1
K1200GT
CB750F 1978
Last edit: 12 years 3 months ago by Toddh.
  • wrgoo56
  • wrgoo56's Avatar
  • Premium Member
  • Premium Member
#2436
We use to do this kinda think with heater controls in GM cars. Here is a tip. the color bands on all diodes is the value of the part. so get a book from Radio shack or a store like that will be a big help. It will tell you which one you need just in case your meter reads it wrong.
Moderators: scotch
Time to create page: 0.164 seconds
