Electrical
Voltage gauge regulator
- kwak1261
12 years 3 months ago
I have a problem.
the fuel gauge and the temp gauge are supplied by the same wire from a small regulator on the left side of the head stock.
this device should supply 7 Volts but mine is supplying 11.45 volts
this makes the gauges give false high readings.
does anyone know of a repair or a replacement for this part
ive looked on MCG but cant find one
any ideas
Ian
any ideas
Ian
Z1300 A4 ZG1300 DFI X2
Z1261J GS1000S
Vmax1200 XT500
Z1261J GS1000S
Vmax1200 XT500
- Toddh
Re: Voltage gauge regulator
No eBay APP ID and/or Cert ID defined in Kunena configurationHere is one listed on Ebay (new) for $119.99, A little higher than list but not too bad.
Or locate a use one.
Regards.
T.
Regards.
T.
KZ1300 A-4 4TH 1300 IN 30 YEARS
KZ1000 D-3/ Z1R
ZX900 GPZ A-3
KZ750 E-1
K1200GT
CB750F 1978
KZ1000 D-3/ Z1R
ZX900 GPZ A-3
KZ750 E-1
K1200GT
CB750F 1978
- strate6
Ian,
It is a very simple component (voltage reducer) & therefore would be very easy for a decent auto electrician or similar to open up & replace the resistor or component inside that has failed, if you cannot find a used one (look to be expensive too).
As long as you let them know what reading it should be sending out, they should be able to help.
Pete F
Pete F
- kwak1261
Wow good find, thanks Toddh. a bit ambitious with the price, might have to be the last resort
Pete, i was thinking the same way
am de soldering all the components from the board and doing a value test.
its already broken so no loss really
Ian
Ian
Z1261J GS1000S
Vmax1200 XT500
Z1261J GS1000S
Vmax1200 XT500
- Toddh
12 years 3 months ago - 12 years 3 months ago
If you come up with the right parts and availability, it might be a good article to save for the forum.
T.
T.
KZ1000 D-3/ Z1R
ZX900 GPZ A-3
KZ750 E-1
K1200GT
CB750F 1978
KZ1000 D-3/ Z1R
ZX900 GPZ A-3
KZ750 E-1
K1200GT
CB750F 1978
Last edit: 12 years 3 months ago by Toddh.
- wrgoo56
We use to do this kinda think with heater controls in GM cars. Here is a tip. the color bands on all diodes is the value of the part. so get a book from Radio shack or a store like that will be a big help. It will tell you which one you need just in case your meter reads it wrong.
Moderators: scotch
