Aftermarket piston rings
- StanG
- Banned
7 years 9 months ago
Just wondering if anyone has a story to tell about these rings:
79-82 KAWASAKI KZ1300 STANDARD PISTON RINGS 62mm 6RINGS INCLUDED 11-KZ1300PR
I've used a different aftermarket set way more expensive then these. If they are good, it would be an affordable purchase!
- Bucko
Re: Aftermarket piston rings
Don't know about the rings specifically but I know of lots of 80's DOHC Honda folks that have successfully used the inexpensive Curiseimage piston kits (which presumably include these rings)
- zed_thirteen
They are replacement rings for the 1370 kit they sell. I had to buy a complete spare set of 6 rings because I broke one of the compression rings in my 1370 kit. I had also sent one of my spare sets of rings to a guy in the states who had also broken one of his 1370 kit rings.
1980 KZ1300 B2 Touring/A2
1980 CBX1000-A
1990 ZZ-R1100 C1
1980 CBX1000-A
1990 ZZ-R1100 C1
- StanG
- Banned
So, they don't fit on a standard bore, right?
- Kawboy
7 years 9 months agoThe EBay listing you show is the right fit for a stock cylinder. The same supplier also sells a 64 mm overbore piston kit with 64mm rings.StanG wrote: So, they don't fit on a standard bore, right?
- StanG
- Banned
Two different answers, but the title says 1300. The 62 mm sounds right, I think I will go with KB on this.
Moderators: scotch
Time to create page: 0.171 seconds
