kz1300 banner
Hydraulic Clutch for Voyager engine
  • Bar
  • Bar's Avatar Topic Author
  • Elite Member
  • Elite Member
5 years 7 months ago
#28071
Good day all,
I know there are many posts on the Hydraulic clutch conversion but none for Voyager engine
Did anyone do this before?
I was trying to go with the pull slave, but the stroke is to short and I do not think it will work.
I can still do the common conversion as the KZ but the gear cover is way to flimsy and holding with two bolts too far from the slave cylinder, it look like it will break on the first clutch pull.
I was thinking of adding another plate on top of the cover, maybe weld to the cover or bolt in and add another anchor point to the engine cover
Maybe weld the support inside and just add the anchor point outside, that will be determined by space.
Any thoughts …..?
Attachment Clutch 4.JPG not found
Attachment Clutch 5.JPG not found
1984 Kawasaki Voyager
2002 Honda CBR954
  • Phil
  • Phil's Avatar
Re: Hydraulic Clutch for Voyager engine
5 years 7 months ago - 5 years 7 months ago
#28072
When I was looking at doing the same 10 years ago I realised that the cover isn't parallel with the actuating mechanism on our engines, so if you were to fit a slave on the cover it would operate the clutch pushrod at a skewed angle. Maybe it won't matter for the sake of a few degrees, so I'll be very interested to see how you get on.
Last edit: 5 years 7 months ago by Phil.
The following user(s) said Thank You: Bar
  • Bar
  • Elite Member
  • Elite Member
#28073
the question if its worth the afford.
I may order a clutch cable and work on this as a side project
It got to the point I want to see this bike on the road
2002 Honda CBR954
The following user(s) said Thank You: Phil
  • Kawboy
  • Kawboy's Avatar
#28074
Let me give you something to think about.
I've had it in the back of my mind that yes, I want to do a hydraulic clutch conversion but mounting the zx10 slave cylinder on the outside of the cover and next to my left foot just didn't appeal to me. My thought was to remove the clutch release actuator and try to fit a smaller slave cylinder under the cover and mounted to the same 2 screw holes that hold the clutch release actuator. Those 2 threaded holes currently bear the force of the present setup so no concerns there. It might take some engineering to marry up a reasonable master cylinder to give the proper axial release travel on the clutch actuator rod without too much force at the clutch lever.
I've seen some KTM and Ducati slaves that might fit under the cover and an adaptor plate wouldn't be too hard to create.
I'll leave that with you to ponder
  • Phil
  • Phil's Avatar
#28075
How about somehow mounting the same slave you've got with the cable higher up & attaching the cable further up the actuating lever so then the arc won't be so long at that point therefore not needing as long a stroke. The mechanical advantage would be lower though making the clutch action at the lever heavier. Just a thought.
  • Bar
  • Elite Member
  • Elite Member
#28076
That was the first thing that cross my mind
I will not be able to use the original location for the slave cylinder, I will need to make a bracket inside the cover to hold it
I will take a look tonight if i have the space for this
2002 Honda CBR954
Moderators: scotch
Time to create page: 0.174 seconds
