kz1300 banner
If you make pieces and parts or provide services for Kawasaki Sixes you may post links here to your business or product catalog. If you're just into 1300's and have found a business that you like to deal with post it up here.
Valve shims
  • oldkawasakidude
  • oldkawasakidude's Avatar Topic Author
  • New Member
  • New Member
Valve shims
12 years 2 weeks ago
#2925
I've got an 84 Voyager that I think will need the valves shimmed. Are the shims readily available? If so from who?
Thanks,
oldkawasakidude
  • Toddh
  • Toddh's Avatar
Re: Valve shims
#2927
Hello O.K.D:
There are four basic ways to obtain shims.
1: If you're doing the work, exchange them at a dealership or independent shop. My local Triumph dealership does this for me at little to no cost. (Depends on the shop)
2: eBay, can be expensive and the least trusted way. I prefer to see the shims I am buying and to see what condition they are in. Also if you are doing this yourself, you should have a micrometer to verify the size. Not all printed sizes are readable on the recycled shim.
3: Procure a complete cylinder head for parts. Assuming there is enough shim-stock to get what you need.
4: Have a local shop do the work for you. At times, I have trailered my bike down there with the valve cover removed and swapped them out right there on the trailer. If you don't have the parts on hand, this can save time. Some shops frown on this, others don't mind.
Don't forget valves need to be adjusted with the engine completely cold.
Regards.
T.
KZ1300 A-4 4TH 1300 IN 30 YEARS
KZ1000 D-3/ Z1R
ZX900 GPZ A-3
KZ750 E-1
K1200GT
CB750F 1978
  • kwak1261
  • kwak1261's Avatar
Re: Valve shims
#2931
Hi
if your a fully paid up member of the Z1000 owners club they have a shim swap service.
send in your old ones and request the replacement sizes
a bit long winded but all done in the post. not sure about overseas post, works fine in the UK
Ian
Z1300 A4 ZG1300 DFI X2
Z1261J GS1000S
Vmax1200 XT500
  • RickG
  • RickG's Avatar
Re: Valve shims
#2932
One word of caution when measuring shims is as Todd has said use a micrometer and NOT a vernier because if the shim is worn in the centre as is often the case the vernier will measure the outer rim and not the centre where a micrometer will measure the centre and the outer rim that way you pick up on worn shims.
You should not use shims that are worn in the centre because if they are put in with the hollow side down there is a chance of them cracking and that is disastrous.
Z1300 A1 x 2
  • Toddh
  • Toddh's Avatar
Re: Valve shims
#2933
If you end up doing this yourself make sure you place a few drops of oil on the tappet. After installing the replacement shim, make sure it freely rotates in the tappet.
T.
KZ1000 D-3/ Z1R
ZX900 GPZ A-3
KZ750 E-1
K1200GT
CB750F 1978
  • Toddh
  • Toddh's Avatar
Re: Valve shims
#2936
No eBay APP ID and/or Cert ID defined in Kunena configurationO.K.D:
If you don't have the tools, you'll need a shim removal took kit. There are multiple places to buy these besides eBay but for example see below.
T.
KZ1000 D-3/ Z1R
ZX900 GPZ A-3
KZ750 E-1
K1200GT
CB750F 1978
Time to create page: 0.159 seconds
