kz1300 banner
rear-brake, tech-advise needed
  • BigSix
  • BigSix's Avatar Topic Author
5 years 4 weeks ago
#29189
Hi Guys,
I took the lady out of her slumber and she, after getting fuel started fine. I though noticed at a crossing that she, even with neutral in, does not roll anymore any noticed the rear-brake blocking. The disc hot, so I paused and made it home. With help from a friend we dismounted the rear-master cylinder and noticed the piston was stuck. We have been able to get him moving again, yet the brake shows the identical symptoms, after around 1 mile the disc is hot. Compare to the front-discs too hot I guess.
What would be your approach ?
Thanks and best regards,
Holger
Z1300 A1/ KZT30AG built 1979
frame KZT30A 004285
engine KZT30A 000288
  • Bucko
  • Bucko's Avatar
Re: rear-brake, tech-advise needed
5 years 4 weeks ago
#29190
The equalizing port (smaller of the two holes) in your master cylinder is blocked and preventing brake fluid from flowing back into the reservoir when you release the brakes. Use a small wire or toothpick to clear the blockage and flush the fluid.
  • BigSix
5 years 4 weeks ago - 5 years 4 weeks ago
#29191
Hey Bucko, thanks. When we dismounted the master-cylinder, we did check if that hole is clean since that was the first idea. It was clean indeed, and at the same time I was able to press one of the pistons back into the caliper. I just ordered myself the below item to see if that will solve it:
Keep your fingers crossed ...
Holger
ebay 172807438951
frame KZT30A 004285
Last edit: 5 years 4 weeks ago by BigSix. Reason: looked bad
  • Neville
  • Neville's Avatar
5 years 4 weeks ago
#29195
I had the same rear brake problem a number of years ago - however, it was my fault as I adjusted the pedal stop to reduce the free play.  Not logical for this to happen if you had no problems last time you ran your 1300 but worth checking?
  • BigSix
5 years 4 weeks ago
#29197
Will check that, though I did not change anything in there.
Holger
frame KZT30A 004285
  • zed_thirteen
  • zed_thirteen's Avatar
5 years 4 weeks ago
#29198
I agree - I've done this too.  Noticed an orange glowing rear disk when passing a motorcycle shop window
1980 KZ1300 B2 Touring/A2
1980 CBX1000-A
1990 ZZ-R1100 C1
