Electrical
AW82-TR1 Coil Upgrade For Z1300 & KZ1300. How To !
- Bob4717
- Junior Member
- kwak1261
Re: AW82-TR1 Coil Upgrade For Z1300 & KZ1300. How To !
12 years 3 months ago
My 10 pence worth
Just to agree that the AW82 coils are perfect to use as a replacement for the old coils and ballast resistor.
they are 2.4 - 2.6 ohm, and you can replace the HT leads.
I have read that any higher and eventually you will damage your cdi unit
Ive just fitted these to my rebuilt A5 and it starts and runs smoothly.
Ian
Ian
Z1300 A4 ZG1300 DFI X2
Z1261J GS1000S
Vmax1200 XT500
Z1261J GS1000S
Vmax1200 XT500
- strate6
Ian,
Spot on mate, thats 100% true.
You can actually see the difference in the quality of spark between the old coils & new coils. Its a "must do" modification just like the Camchain Tensioner.
Pete F
Pete F
- Clark
- Junior Member
12 years 2 months ago
I'm getting set up to do the swap on my 13. I have the coils and am in the process of ordering new plug wire and ends. My question is, what caps are you using on the coil end if any? My coils came without wires and all the caps off my original stuff is hard and brittle.
- kwak1261
Clark
your coils should have a thin plastic washer that just fits over your HT lead
( in fact its a Buggah to get on ) and a screw on plastic cap that holds it all together on the coils. ( a bit of silicone grease helps you get the lead into the coil )
ive not seen these caps for sale on there own, they normally come with the coil pack
you can get a DW82 coil from a gold wing they have the same screw on caps but are a higher ohm coil
i used silicone HT lead with NGK plug caps
Ian
Ian
Z1261J GS1000S
Vmax1200 XT500
Z1261J GS1000S
Vmax1200 XT500
- Clark
- Junior Member
Thanks Ian. My coils didn't come with the caps. I'm sure I can make something work until I come across the correct caps.
Moderators: scotch
Time to create page: 0.156 seconds
