kz1300 banner
Electrical
AW82-TR1 Coil Upgrade For Z1300 & KZ1300. How To !
  • wrgoo56
  • wrgoo56's Avatar
  • Premium Member
  • Premium Member
Re: AW82-TR1 Coil Upgrade For Z1300 & KZ1300. How To !
12 years 1 month ago
#3120
Ok lets get down to this replacing coils job. I took the 2&5 coil off the bike to get a good look at this and size things up. 1 these ACCEL coils are a lot bigger than the stock one and the to mount them like the old coils the spare towels are pointing the wrong way. So here is my request, The one's of you that have mounted these coils on your bikes send me so picture of how yours are done. In other words give me some ideas. ( I am not interesting in keeping the bike looking totally stock.) so with that said I will make shit fit but do a nice job. If need be I will mount these coils some place else away from the heat. Ideas guys?
  • RickG
  • RickG's Avatar
#3128
My thoughts about placing the coils away from the heat is that the standard coils were totally inadequate for the job including the heat they get. The Kawasakis are the only Japanese bikes that I come across that have this problem on a regular basis from early in life. It is not just the 13s the early Z9s and Z1000s were as bad.
The rest seem to handle the heat OK and the auto coils also need to handle the heat better as under the bonnet of a car gets far hotter than any bike would so I don't see any need to mount them some cooler place, it's more getting rid of coils that are not up to the job.
Z1300 A1 x 2
  • wrgoo56
  • wrgoo56's Avatar
  • Premium Member
  • Premium Member
#3131
Ok Rick your the one I was hoping would answer. The center post that run thru the coil that the bolt go thru turns the towers strieght up or down so it looks like I am going to have to make me a bracket to mount to the plate so I can turn the towers sideway. I agree with you an Accel coil should be able to take the heat. So give this a shot and take picture's a long the way. Frankly I was not sure where to move them out side the where the factory put them to start with.
  • RickG
  • RickG's Avatar
#3134
I don't see why they can't be turned sideways.
I figure that you fit them any way that suits as there is very limited room under there to fit anything.
Z1300 A1 x 2
  • Phil
  • Phil's Avatar
#3148
I mounted my Dyna coils to the valve covers, my thinking was that they'd get a cooling breeze there as the air comes through that gap between the engine & underside of the fuel tank from the front & also when the radiator fan operates at a standstill. Had them in that location for quite a few years now, no problems. Ignore the red arrow as that was for another post elsewhere.
  • Tad
  • Tad's Avatar
  • Premium Member
  • Premium Member
12 years 1 day ago
#3696
hey all
question for Pete or anyone hving done the upgrade.
when you say make a 3 way loom from the pink wire source, do you mean from the source feed all 3 coil negatives with 3 wires from the 1 ?
just wanna get it right.!!!!
Tad
Moderators: scotch
Time to create page: 0.186 seconds
