Electrical
AW82-TR1 Coil Upgrade For Z1300 & KZ1300. How To !
- met1212
- Senior Member
Re: Coil Upgrade For a 1979 KZ1300.
11 years 7 months ago
hi pete,
thanks for the upgrade details.
i have tested my original coils to a measurement of 2 ohms....
the manual says 1.5 to 1.9 ohms....so i guess thats why im not getting a good spark.
so with this in mind, i guess im up for an upgrade such as yours....
the ballast resistor you mention above, is this also known as part number 28018-1014 RESISTOR,IGNITION,COIL or is it the IGNITER part number 21119-1005? is there a picture of it in cyberspace somewhere so that i can eyeball it....im not familiar with these bikes so any type of research before i start is good....thanks again
- aus_z1300
- Elite Member
Re: AW82-TR1 Coil Upgrade For Z1300 & KZ1300. How To !
11 years 7 months ago - 11 years 7 months ago
It's white ceramic and has 3 pink wires and 1 yellow i think left side of the frame in the coil vicinity.
http://t0.gstatic.com/images?q=tbn:ANd9GcSPvNv5u9u5DHst_1yArQ05IXcEji8Mo1rL7QtAHW9Ebps_N1sAbw
Last edit: 11 years 7 months ago by aus_z1300.
The following user(s) said Thank You: met1212
- met1212
- Senior Member
yeah got it.....
looking at coils now.
nology profire and accel have them for about $400 delivered new....
the most obvious option is the honda cb900 coils, not only because they are substantially cheaper but also because every write up suggests they are just as good....my only problem there being second hand, would be paying $150 for them delivered and finding out they are on their way out....hmmmm......decisions....
- aus_z1300
- Elite Member
Aw82 coils bolt straight in no messing about trying to fit them .And when you buy them you normally have to buy two pair so you will always have a spare lol.
- rdbhere2
- Elite Member
11 years 1 month ago
my new aw82-tr1 ( Honda gl100, Honda 750) coils are measuring 2.2 ohms. do I still need the ballast resister?
- aus_z1300
- Elite Member
From what i have read it says they should be between 2.5 and 2.7 are you sure your multimeter is ok.
Moderators: scotch
