kz1300 banner
Electrical
AW82-TR1 Coil Upgrade For Z1300 & KZ1300. How To !
  • Kawboy
  • Kawboy's Avatar
Re: AW82-TR1 Coil Upgrade For Z1300 & KZ1300. How To !
5 years 11 months ago - 5 years 11 months ago
#27356
One of our members went with .4 Ohm resistors Beru WZ04-2.
.4 Ohm Beru WZ04-2 resistor
Same resistor EBay option
EBay Beru.4 ohm resistor
Last edit: 5 years 11 months ago by Kawboy.
The following user(s) said Thank You: fabio
  • fabio
  • fabio's Avatar
  • Junior Member
  • Junior Member
5 years 9 months ago
#27745
At the end with 3 new coils ( primary with 2.5- 2.9 ohms)i shorten the original ballast from 1.9 to 0.5 ohms ,but again weak sparks and very fouled spark plugs.
So i removed all the ballast ,the current in each coils increase from 0.6 to 0.9 A (is it high for the transistor?)but nothing change.
Today i remove the spark plug cap resistor (5 Kohms) and the spark now is good,i dont know about the fouling because i'm worried about this changes and i stop the engine.
Could be dangerous for the engine,transistor etc. ?
thank
fabio
  • strate6
  • strate6's Avatar Topic Author
5 years 9 months ago - 5 years 9 months ago
#27751
I have came into this post on the back end..........................I dont understand............but why all the talk about messing around with resistors etc. ???????
Just fit 3 x AW82 coils and bin the Ballast Resistor .....................job done !!!
I have done this to all my 11 x Z1300's and KZ1300's and numerous friends Z1300's and NEVER EVER have any of the bikes had an issue or problem or any need what so ever to mess around with resistors !!
Why make things more complicated and difficult when all is needed is a straight swap of the 3 coils.......end of.........job done.........completion.......nomore ???????
Pete F
UK
Last edit: 5 years 9 months ago by strate6.
The following user(s) said Thank You: McBoney
  • CWB
  • CWB's Avatar
  • Senior Member
  • Senior Member
#27767
Hey "Bro" this "Bro" thank you profusely for the excellent unambiguous write up and better placement of the topic. I did remember reading this some time ago and was just in the process of looking for it as a starting point. Noted that the stampAW82-TR1 is required .
Bill
Aus
  • McBoney
  • McBoney's Avatar
#27782
strate6 wrote: I have came into this post on the back end..........................I dont understand............but why all the talk about messing around with resistors etc. ???????
Pete F
UK
I can concur. I did the same thing, no issues whatsoever, Lithium-ion battery and all...
Six-Pot-Cafe in the making...
  • ronlander
  • ronlander's Avatar
  • Junior Member
  • Junior Member
5 years 6 months ago
#28316
Hey guys, I have an extra ballast (Bosch) holder for the AW82-TR1 Coil Upgrade, I had two made, not my best work but it will do, it's made from stainless steel so it will not rust, willing to give it for free to anyone from the forum. PM me with an address and Ill send it out.
Mary Christmas and Happy Hanukkah to all.
Moderators: scotch
Time to create page: 0.189 seconds
