Electrical
AW82-TR1 Coil Upgrade For Z1300 & KZ1300. How To !
- Kawboy
Re: AW82-TR1 Coil Upgrade For Z1300 & KZ1300. How To !
11 years 3 weeks agordbhere2 wrote: Sounds like a great idea. I was tempted to run my coils without resisters and just buy a cheap igniter to sacrifice if I had to. I use run /turn lights on the rear and replaced all bulbs to led and went from 12.7 charging to 13.6.charging. Hopefully when I put the heavy duty stator on that will bump up a little.
You'll want to rethink the nylon wire tie wraps. the reason the resistor are made with a ceramic shell is because the resistor itself turns into an element and will glow cherry hot. Then the tie wraps will melt and then you've got an ignition hazard floating around underneath a fuel tank and then, well, we probably won't hear from you again. :evil: :ohmy:
- scotch
Always High - Know Fear !
- rdbhere2
- Elite Member
11 years 3 weeks ago - 10 years 9 months ago
My new coils measured 1.7 ohms along with these ceramic .47 ohm resisters I have really good spark.
Last edit: 10 years 9 months ago by rdbhere2.
- Yaegunp
- Elite Member
10 years 7 months agostrate6 wrote: Fellow Owners.......
Equipment list to carry out this upgrade.
3 x Good AW82 Coils. Should be tested & show around 2.4 ohms.
6 Feet of good quality copper core 7mm wide HT (high tension) Lead.
6 x FEMALE spade terminals (crimp are fine but solder even better!).
2 Feet of yellow electrical wire 10 amp minimum.
1 x Foot of each GREEN & BLACK & BLUE electrical wire 10 amp minimum.
3 x Bullet connectors to extend each colour wire above to reach the AW82 coils.
Pete F
Do HT leads have to made from copper core? I'm having trouble sourcing copper core.
1983 Z1300 A5 plus Sidecar.
- Kawboy
Lots of suppliers on EBay. shouldn't be that hard to find. Solid core wire for sure since it needs to screw into the coils. Copper has less resistance than the steel wire, but the leads are short enough that steel core wire would be fine if stuck and can't find copper.
The following user(s) said Thank You: Yaegunp
- Yaegunp
- Elite Member
Thanks Kawboy. I managed to get the bike started yesterday and found that the existing HT leads were a bit dodgy. I am very anxious to see if I can get the old girl going properly. I'm a bit like a kid in a lolly shop and didn't want to wait for some order to arrive off ebay :silly:
Moderators: scotch
Time to create page: 0.208 seconds
