kz1300 banner
C.C.T.
  • scotch
  • scotch's Avatar Topic Author
C.C.T.
4 years 10 months ago - 4 years 10 months ago
#29579
Has anyone found a replacement/alternative part for the C.C.T. rubber-roller?   Mine looked great until I discovered radial cracks on both sides.
Always High - Know Fear !
Last edit: 4 years 10 months ago by scotch.
  • Kawboy
  • Kawboy's Avatar
Re: C.C.T.
#29580
Last edit: 4 years 10 months ago by Kawboy.
  • scotch
Re: C.C.T.
#29581
Thanks KB.  On that site I found one that says Original Kawasaki and it appears OEM but how the Hell do you order anything from them ?
www.z1300.de      Not  a user-friendly site for the English speaking.
Elsewhere I also see another Kawasaki roller;  and the use of a different style chain makes these inapplicable as you stated.
  • Kawboy
  • Kawboy's Avatar
Re: C.C.T.
#29582
The subject of communicating with the site has come up in the past. if you send them an email in English, they are more than happy to assist. ( I seem to recall Lares advising us of this)
Hope this helps.
  • biltonjim
  • biltonjim's Avatar
Re: C.C.T.
#29609
Scotch, Have you sourced a cam chain roller yet?   How is the rest of your top-end overhaul progressing?
  • scotch
Re: C.C.T.
#29610
RE: Cam chain roller  Thanks to kawboy for getting this rolling
"Gordon"  has indicated that he can make a roller using "plastic".  It sounds like this would be a "one of" for $60.00 us.
 The bearings used in the sprocket and roller are "J-78", readily available - I purchased one for $7.00, locally and am currently "smashing eggs" !
I've mocked-up a two rollers - 1 nylon and one rubber.  Still playing with these.
I took my cyl-block, head, pistons and valves to a machine shop last week. They are busy.   Am expecting a call in a few days to let me know how things measured-up.
I'm prepared to buy new pistons/rings if required.   +0.5mm and +1.0mm are available. I'm not interested in a Big Bore kit although it's ironic that a B.B. kit is cheaper.
I 've had some discussion with 2 trusted people about using a ball-bearing in place of the roller.
The specific size is hard to find but I did finally get a bearing #.  11 mm bore is NOT common.  none-the-less - The consensus is "No".  I'll leave it that !
The following user(s) said Thank You: biltonjim, zed_thirteen
Moderators: scotch
Time to create page: 0.164 seconds
