kz1300 banner
Regrettable Engine strip down !!!! I think " Follow up". But it's not over.
  • Kawboy
  • Kawboy's Avatar
Re: Regrettable Engine strip down !!!! I think " Follow up". But it's not over.
3 months 2 weeks ago - 3 months 2 weeks ago
#34559
Pretty sure what you're looking at here is oil that was sitting on the top ring and as you rolled the pistons down, that oil slid down the cylinder walls. If you wiped down the cylinder walls and rolled the pistons through, the cylinder walls would be oil free. (should be anyways.)
Oil in the airbox can only come from oil vapors that condensed in the airbox from the PCV system. That much vapor coming from the PCV is generated by blowby around the piston rings. But again, you're compression numbers tell a completely different story. I'm at a loss.
Last edit: 3 months 2 weeks ago by Kawboy.
  • z13phil
  • z13phil's Avatar Topic Author
#34563
Hi Kawboy,  I have wiped the bore's and every time the pistons go up and down its like a oil pump. Particularly on #1-2-6
  • Kawboy
  • Kawboy's Avatar
#34566
Wierd. Only one thing left  to do. Pull the cylinder block and take it from there.  Can't wait to here what you find.
  • scotch
  • scotch's Avatar
#34567
I've been thinking this thru and am also coming-up "blank".
I do have a thought about trying to prove more definitively as to from where specifically and how, that oil is getting to your piston tops.   If you are getting oil  simply by turning the engine over by hand then Pressurize the oil system with air; starting from "0" P.S.I.  and gradually increasing to a few lbs, using a regulator.  The "boost"  might better prove the source(s)
Always High - Know Fear !
  • z13phil
3 months 1 week ago
#34572
Yes Kawboy, this is under way. But  at a stand still at the moment,   This is not like working on mt Z1R  !!!! Just worried about the the nylon bevel gear on that shaft that goes to the small timing sprocket.
Will they fall off as i withdraw the shaft. O lord how do they go back on afterwards ?
  • Kawboy
  • Kawboy's Avatar
3 months 1 week ago
#34573
Just follow the Factory Service Manual and you'll be fine. It's pretty straight forward.
The following user(s) said Thank You: z13phil
Moderators: scotch
Time to create page: 0.170 seconds
