kz1300 banner
Fuel tank blues
  • Mightyzod
  • Mightyzod's Avatar Topic Author
  • New Member
  • New Member
Re: Fuel tank blues
9 years 10 months ago
#13979
Globemaster:
When I place the tank as you suggest, with the tank far to the rear of the bike and the cups and bolt hole lined up, all is well. As soon as I start moving the tank forward, it hits the frame and begins to rise in the back. Also, the U shaped channels are loose, from left to right, when they are on the rubber caps. You describe the exact method for putting on a gas tank, which I have done many times. What is preventing this simple task from taking place is beyond me, at this time.
Charlie9670:
One of the photographs in the previous submissions shows where the grey from the back of the tank is rubbing the middle bar of the frame near the rear mount raising the tank so the tank and frame mounts are misaligned. We aren't sure if that is the problem area, but it goes along with what you suggested to help find the problem.
We spent over an hour last night trying to complete this job. Very frustrating.
MZ
  • globemaster
  • globemaster's Avatar
Re: Fuel tank blues
#13984
Mightyzod,
Sorry I can't be of more help. You certainly have my sympathy. This is a very unique problem.
The following user(s) said Thank You: Mightyzod
  • charlie9670
  • charlie9670's Avatar
  • Elite Member
  • Elite Member
Re: Fuel tank blues
#13987
Certainly is a strange one, either the frame has been bent or altered which seems unlikely ,or the tank has altered, is it possible the tank tunnel has been narrowed by extreme heat/pressure ,a jack inside would open it up a bit but only thinking of a last resort!
:) Z13 UK
  • zed_thirteen
  • zed_thirteen's Avatar
Re: Fuel tank blues
#13993
I've had this happen when the connector for the fuel level sender gets stuck between the tank and the frame. Just a thought.
I think you need to hold it to the side as the tank goes on and then connect it up under the frame rails - a little bit fiddly without assistance.
1980 KZ1300 B2 Touring/A2
1980 CBX1000-A
1990 ZZ-R1100 C1
  • homer01
  • homer01's Avatar
  • Premium Member
  • Premium Member
Re: Fuel tank blues
#14008
has the tank been pressurised and bloated underneath somewhere causing it to sit up on the frame
  • Mark
  • Mark's Avatar
  • Elite Member
  • Elite Member
Re: Fuel tank blues
#14022
Is there a difference between the B and A model frame. Exact same as yours on UK Ebay 351786747008
17 years a Z13 owner at present 3 x A1's and an A4
