kz1300 banner
1982 KZ1300 rescue and rebuild
  • scotch
  • scotch's Avatar
Re: 1982 KZ1300 rescue and rebuild
7 years 9 months ago - 7 years 9 months ago
#21250
Smokin' - I agree that the mod should come out. This will be interesting. Your carbs didn't give a hint of a "puff" on my bike when I set them up but .....
It's the start without the mod that I'm interested in.
Perhaps you can try something before you remove your carbs. See how it starts with only partial - 1/2, choke. Would appreciate the feedback.
Always High - Know Fear !
Last edit: 7 years 9 months ago by scotch.
  • StanG
  • StanG's Avatar Topic Author
  • Banned
  • Banned
#21252
About the speedo, yes, I'm aware of the preload tension. The needles need to be placed exactly where the old were, which is a bit tricky without those little knobs. But apparently it's been successfully done many times, and now I don't have a choice!... The old needles just shattered. They were both like long curvy eyelashes way above those stop pins. Thank you for getting the drill idea out of my head KB. I have to sleep on it and think. More reasoning about it below..
The mileage per Richard's question. Not sure about the 'odometer culture' here, I just have no idea. But one thing I've heard is that motorcycles competing for originality are very closely scrutinized. For example, stripes applied to the tank must reflect on the era and can't be too pretty. When some old bike gets new lines painted, they should be done the same way by hand mimicking sometimes the shaky hand that painted them decades ago. I've heard judges will look even if the washers are original. When doing repairs welding, the welds must also resemble the old sometimes not so pretty welds, not be so beautiful and even like they come out using modern tools. My KZ has some really ugly welds on it for example! There are even a couple places where the welding core wire got stuck and broken of, never cleaned up afterwards. That's definitely some personalized history to see right there! haha In my bike's case, I definitely crossed the line, I guess I don't need mention having a black engine for starters! hahaha And I am definitely not going to apply any of the ugly warning and instructional stickers all over the bike. But I agree, my gut wants to keep the odometer numbers original.
Maybe other Canadian fellows could educate us about how the originality works here?
Yes, ideally, I'd like to keep the numbers original. And I have the original numbers well documented. I am totally with you on this. The problem is the new speedo, which I want to install, comes with a totally different mileage. It has 54044 kilometers on it, while the original one about 8500 miles. So, I'd like to convert those miles to kilometers and set the replacement speedo to the correct corresponding number. I guess I just threw that 'zero start' idea up in the air without a deeper thought nor seriousness.
And I see this might be tricky. I didn't plan on digging into the gears this much, but maybe that should become a plan.
The carbs and start. I will experiment more and see. The general finding so far is it needs leaner mixture when on choke, and the vacuum mod might be the culprit sucking in too much fuel, which gets helped with some extra air already at start up by opening the butterflies but keeping the choke not fully applied. I'll see today what happens at 1/2 point, but I think the mod has to come out eventually in my bike's case. Which doesn't mean it a flawed mod, I'd say it's probably a good solution for bikes with higher mileage and already cold start problems.
I am sticking to my new/original plan - put together another carb set and make a switch. I will have to do it anyway, to test and tune the new set to keep as backup (or for sale to recuperate some funds). When this proves to work well, I will remove the mod from the original set and this would be interesting to see exactly what impact that would have.
As to setting the carbs, I have spare boots which and I will make a manifold with a hook up to a vacuum for bench synchronizing. I haven't seen your set up scotch, but I have an idea how I'm going to go about it. I am also working on contacts to have a place where I can do the float levels without worrying about stinking the place up.
  • scotch
  • scotch's Avatar
#21253
Had the same issue with brittle instrument needles. Got some from Lare and the re & re was easy enough with care. Resetting the K-speedo to the engines actual mileage makes sense. Going back to "0" , not so much.
The welding on the frame was bad on mine, too. The electroplater who did the nickel on mine spent some time addressing the nasty welds. Todays "robotic" welding lays down nice beads.
Rather then wait for a response regarding the "1/2" choke for cold start I'll point something out, now. When the choke is applied about 1/2 or less the air-port is completely blocked by the plunger ! No mixing-air ! The plungers must be raised about 1/8" off the seat before the air-port starts being exposed. The difference of course is that this setting has now opened the throttle-plates, by means of the fast-idle cam/roller. Potentially this should give you the choke-fuel required but the curiosity is about how easily it starts with the throttle-plates opened slightly at this setting and of course whether there's "smoke" and if so how much, relative to the modified full-choke procedure.
  • StanG
  • Banned
  • Banned
#21254
I'm just about to hit the stairs and go for a ride, so a quickie here.
Yesterday cold start my 'modified' way - not a trace of any smoke at all. Also, just checking the exhaust, it's clean I could literally eat of it.
  • StanG
  • Banned
  • Banned
#21256
I don't know if that's what you suggested scotch, but I positioned the lever half in the middle between off and top full positions. Pressed the run button and I think the bike started sooner than I could remove the finger from it! It shoot immediately to about 5000 rpm's, so I eased it off to about 1100. The bike just started idling like a cold bike, until it warmed up. I controlled the rpm's to keep them around 1000+ every time they started increasing. Not a trace of smoke from start till end.
I guess the 'choke' shouldn't be actually just called a choke anyway. It's not a choke, it's rather a fuel enricher! ;)
  • scotch
  • scotch's Avatar
#21257
Well there you go. Interesting.
Hence forth to be known as the "Choke Fuel Enricher".
Thanks!
Moderators: dcarver220b
Time to create page: 0.210 seconds
