A3 Z1300 resto in Oz
- Tuckabag
- Senior Member
Re: A2 Z1300 resto in Oz
10 years 1 month ago
Is there a way to edit the thread title?
Need to change from A2 to A3!
1980 Z1300, 2006 SV650, 1956 BMW R25/3 resto project, 1999 Husky WR250
- kwak1261
10 years 1 month agotry putting the whole thing into the ultrasonic cleaner, try again when its finished and hot, all mine came undone very easy.
Z1300 A4 ZG1300 DFI X2
Z1261J GS1000S
Vmax1200 XT500
Z1261J GS1000S
Vmax1200 XT500
- Tuckabag
- Senior Member
Thanks.
Had tried that. Will give it a few more goes.
It is purely a drain screw yeah? No other function?
- Kawboy
Yes, just a drain screw.
Do yourself a favour and sacrifice a screwdriver just for this screw. Find a screwdriver the same width and then grind down the flat on the screwdriver to make the blade thicker. The purpose here is to fit the end of the screwdriver in the slot of the screw until it's almost too tight to fit the screw. That way when you apply torque to the screwdriver the entire slot is taking the force of the blade rather than the ends of the blade working on the ends of the slot of the screw.
the other trick that works well is to put your new screwdriver into the screw and tap the handle of the screwdriver with a hammer while applying a torque on the handle in the counter clockwise direction. Usually the shock from the hammer will break the screw free.
- Tuckabag
- Senior Member
Re: A3 Z1300 resto in Oz
10 years 1 month ago - 10 years 1 month agoKawboy wrote: Yes, just a drain screw.
Thanks, I'll give that a shot tonight and see how we go.
Just picked up a bunch of S/S Sockethead Capscrews to replace the crap Phillips head screws......
Is the drain screw readily available as a spare part? (in case I butcher it!)
Last edit: 10 years 1 month ago by Tuckabag.
- Tuckabag
- Senior Member
10 years 1 month agoTuckabag wrote: Is there a way to edit the thread title?
nevermind, I worked it out in the end!
Moderators: dcarver220b
Time to create page: 0.186 seconds
