kz1300 banner
THE MOMENT OF TRUE.
  • zed_thirteen
  • zed_thirteen's Avatar
Re: THE MOMENT OF TRUE.
1 year 11 months ago - 1 year 11 months ago
#32716
If you remove the clutch adjuster cover (three screws) there is an adjuster. With slack in the cable,  slacken the lock-nut and then turn the center rod with a screwdriver.  Turn it in (clockwise) until you feel resistance and then back it off 1/4 turn (I think it's quarter turn?), then lock it off again.
Anyway, if this center push rod is too tight the clutch can slip - probably more when it expands through heat.
1980 KZ1300 B2 Touring/A2
1980 CBX1000-A
1990 ZZ-R1100 C1
Last edit: 1 year 11 months ago by zed_thirteen.
  • Kawboy
  • Kawboy's Avatar
#32717
You beat me to it by 4 minutes. LOL !! Yes, my exact thoughts. The push rod is bottomed out.
  • giorgi3
  • giorgi3's Avatar
  • Senior Member
  • Senior Member
#32718
Sounds pretty good in the 'First Test Ride' video!
  • kawaBCN
  • kawaBCN's Avatar Topic Author
#32720
If you remove the clutch adjuster cover (three screws) there is an adjuster. With slack in the cable,  slacken the lock-nut and then turn the center rod with a screwdriver.  Turn it in (clockwise) until you feel resistance and then back it off 1/4 turn (I think it's quarter turn?), then lock it off again.Anyway, if this center push rod is too tight the clutch can slip - probably more when it expands through heat.
As soon as I have a moment I'll check this tensioner part, although I didn't touch anything about how it was calibrated when I took the engine apart and took the tensioner cover off.
I will also bleed the brakes again to rule out a brake pump pressure problem.
Regarding the suspension to end the effect of riding a horse-drawn stagecoach from the Far West.What maximum air pressure should I inject into each fork leg for it to work and not break the seals?
I also intend to change the oil, how much does each fork arm have?
RUN LIKE THE WIND¡¡¡
Last edit: 1 year 11 months ago by kawaBCN.
  • Kawboy
  • Kawboy's Avatar
#32721
Front Fork oil change is covered in the manual on page 226.  It calls for SAE 10W20 oil . 360cc oil per fork if your just changing the oil.  391 cc of oil if you disassemble the forks and rebuild.
As far as the clutch problem- I don't know how many times I've seen people with clutch problems because they didn't know about the pushrod adjustment. I've seen bike sold because of clutch /transmission problems and then found out it was just a pushrod adjustment issue.
The following user(s) said Thank You: kawaBCN
  • Kawboy
  • Kawboy's Avatar
#32722
The front fork air pressure is covered in the Operating Manual on page 81.
Air pressure should be between 50- 70 Kpa ( 7.1 - 10 psi.)
Moderators: dcarver220b
Time to create page: 0.196 seconds
