Big Bore Kit
- kza13
Re: Big Bore Kit
12 years 4 months ago
I used an egg ring, the thing you fry eggs in to keep them round, cut at an angle and a large hose clamp to compress the rings, but I had the whole engine pulled down at the time and put the pistons in and then connected the rods to the crank later before putting the bottom case on, things we use when we get thinking, did the job well as the egg ring is aluminium and didn't hurt the rings, I hate to admit I used it, but it worked
Frame No: KZT3OA003911
Engine No: KZT3OAE004153
- zed_thirteen
Re: Big Bore Kit
12 years 3 months ago
Barrels are off again ready to be bored out.
The liner thickness is 2.3mm at the bottom end.
As the new pistons are 2mm larger than standard I guess this means that about 1mm of the liner has to be removed leaving a liner thickness of 1.3mm.
I think I mentioned earlier that I thought the Cruzinimage pistons felt a little light. Well the original 62mm pistons are 160g and the new 64mm pistons are 156g - so maybe just a shade lighter.
I've no idea what grade of aluminium the new pistons are made of but I've put some comparison photos in my photobucket folder here:
Regards
David
Regards
David
1980 KZ1300 B2 Touring/A2
1980 CBX1000-A
1990 ZZ-R1100 C1
1980 CBX1000-A
1990 ZZ-R1100 C1
- strate6
Re: Big Bore Kit
David,
Thank you for your time & dedication to this topic.
I really considered this big bore kit for my own bike before the rebuild (as its so cheap) but found the bores so good on my own bike after the strip that I did not feel it worth the added expense so just replaced the rings.
Your pics of the new pistons look really good in my opinion.
I have no reason to doubt this will work perfectly well for you & would be grateful if you will keep us updated how it goes.
Pete F
Pete F
- zed_thirteen
Re: Big Bore Kit
12 years 3 months ago - 12 years 3 months ago
block and new pistons are at the machine shop now. Should have it back in a week.
I'm going to need a new impeller and it looks like I'm going to have to get a very expensive CNC machined one from Germany
Mine has rounded off in the key-way - just like my last one did! I'm hoping I'll be able to get the ceramic part of the mechanical seal out of mine without breaking it as it was brand new.
1980 CBX1000-A
1990 ZZ-R1100 C1
1980 CBX1000-A
1990 ZZ-R1100 C1
Last edit: 12 years 3 months ago by zed_thirteen. Reason: spelling and grammar
- Toddh
Re: Big Bore Kit
12 years 3 months agozed_thirteen wrote: Barrels are off again ready to be bored out.
Regards
David
David:
Have you been able to research or tell of 1.3mm will be enough sleeve? Seems a bit thin?
T.
KZ1300 A-4 4TH 1300 IN 30 YEARS
KZ1000 D-3/ Z1R
ZX900 GPZ A-3
KZ750 E-1
K1200GT
CB750F 1978
KZ1000 D-3/ Z1R
ZX900 GPZ A-3
KZ750 E-1
K1200GT
CB750F 1978
- kwak1261
Re: Big Bore Kit
ill run this idea by you all and see what you think, i know a man that has done this on a Z1000.
Have new con rods made 10mm longer, have new pistons made with the wrist pin 10mm higher, just below the oil ring.
this would give you an extra 10mm of swept bore without over sizing the sleeve, and less force on the liner increasing the revlimit at the same time.
loads of engineering work for the enthusiast.
Z1300 A4 ZG1300 DFI X2
Z1261J GS1000S
Vmax1200 XT500
Z1261J GS1000S
Vmax1200 XT500
Moderators: scotch
Time to create page: 0.170 seconds
