kz1300 banner
Big Bore Kit
  • kwak1261
  • kwak1261's Avatar
Re: Big Bore Kit
12 years 2 months ago - 12 years 2 months ago
#2607
you can still get a genuine head gaskets with all the water way seals on it £98
i got mine to that stage then put the engine in the frame before putting the head on.
cut some tube to go over the studs to bolt the barrels down while being handled.
Z1300 A4 ZG1300 DFI X2
Z1261J GS1000S
Vmax1200 XT500
Last edit: 12 years 2 months ago by kwak1261.
  • zed_thirteen
  • zed_thirteen's Avatar
Re: Big Bore Kit
#2611
but the diameter of the fire rings is only 62mm and not 64mm. I think this means that the barrels will compress the fire rings 1mm from the edge and combustion will quickly start to burn past them.
I want to use the new gasket with the 64mm fire rings but make sure I seal the water jackets properly. I hear that this 3Bond 1211 is the best stuff to use.
1980 KZ1300 B2 Touring/A2
1980 CBX1000-A
1990 ZZ-R1100 C1
  • kwak1261
  • kwak1261's Avatar
Re: Big Bore Kit
#2613
Of course, excuse my ignorance, its a big bore.
i blame my age, getting worse.. tum te tum...
not heard of 3bond 1211
Z1261J GS1000S
Vmax1200 XT500
  • RickG
  • RickG's Avatar
Re: Big Bore Kit
#2614
Try a BMW dealer for Drei bond it's virtually the same stuff or www.dreibond.com.pl/
Z1300 A1 x 2
  • zed_thirteen
Re: Big Bore Kit
#2804
isn't this a beautiful sight?
Hopefully it wont be long before they are all going "bang, bang, bang, bang, bang & bang..."
1980 CBX1000-A
1990 ZZ-R1100 C1
Last edit: 12 years 2 months ago by zed_thirteen. Reason: spelling!
  • strate6
  • strate6's Avatar
Re: Big Bore Kit
#2815
Ahh yes, I remember that well & not too long ago either !!
Its great when you get to that stage, as its pretty much just bolting everything on after that !!
Good luck with the rest of the build & very interested to hear your thoughts & findings on the big bore kit as its something I have considered for a while now (maybe next winter project?).
Pete F
Moderators: scotch
