- Thank you received: 4
Big Bore Kit
- Dinosaur
- Junior Member
12 years 4 months ago #1567
by Dinosaur
Paul
Big Bore Kit was created by Dinosaur
Hi to all.when talking about a big bore kit what size of pistons will be big bore on a 1300?
Paul
- RickG
- Thank you received: 92
12 years 4 months ago #1573
by RickG
Z1300 A1 x 2
Replied by RickG on topic Big Bore Kit
The kit I have to use is 2mm bigger than standard.
Z1300 A1 x 2
The following user(s) said Thank You: Dinosaur
- rob
- Senior Member
- Thank you received: 11
12 years 4 months ago #1594
by rob
Replied by rob on topic Big Bore Kit
Hi Dinosaur
I have used one of these kits without any problems. Machine shop manufactured outer tubes to fit around piston sleeves at the bottom of the barrels so as not to end up with an oval bore after machining. There is not much meat left on the piston sleeves after machining but this upgrade has worked well. Lots more torque and low down power. Money well spent.
- rob
- Senior Member
12 years 4 months ago #1595
by rob
Forgot to mention. bought this kit.
78-82 Kawasaki KZ1300 1370cc Bigbore Piston Kits with Head Gasket KZ1300BB
You will find it on ebay.
- Petez13
- Thank you received: 3
12 years 4 months ago #1601
by Petez13
Replied by Petez13 on topic Big Bore Kit
Hi,
I was also thinking of going for a big bore kit but wasn't sure which one to go for, I read some time ago that someone used 750 pistons to take the cc upto 1500, but that seemed like a lot of work.
So 1370cc seems to be the usual size but not sure what kit to go for
I've seen on eBay a kit from japan I think from CruzinImage, ( I think can be bought from zpower as well) which isn't too expensive, but not sure on quality.
Another kit was by Forseti, which seemed to be advertised as high quality.
I've also seen a kit from the USA but can't remember the supplier on eBay which was priced at $500 (I think )
so has anybody used any of these and any problems?
It's been said that you should always use the original head gasket, I guess in this case you can't, so has anyone had problems with leaking head gaskets?
Thanks for any info, Pete.
- zed_thirteen
- Thank you received: 147
12 years 4 months ago - 12 years 4 months ago #1774
by zed_thirteen
1980 KZ1300 B2 Touring/A2
1980 CBX1000-A
1990 ZZ-R1100 C1
Replied by zed_thirteen on topic Big Bore Kit
I've just bought the Cruising image 1370 big bore kit from Japan. Ordered it on Sunday night and it was delivered on Wednesday with just the standard delivery option.
The quality looks reasonable. The pistons feel very light but I don't have an original to compare against.
Will be a while before I strip the barrels and get the machining done.
here's a picture of one of the pistons:
1980 CBX1000-A
1990 ZZ-R1100 C1
Last edit: 12 years 4 months ago by zed_thirteen. Reason: correct spellign and grammar
Moderators: scotch
Time to create page: 0.123 seconds
