Big Bore Kit
- zed_thirteen
Re: Big Bore Kit
12 years 1 month ago
Bugger!
I treated the big bore 1370 head gasket with Hylomar spray gasket seal on both sides and then put a bead of ThreeBond 1211 selant around all of the water jackets on both sides and a small bead around the oil passageways for good measure.
Each coat of gasket seal is ready in 10 minutes and the 1211 skins over in 30 minutes.
While installing the head I managed to drop a small screw driver down the cam chain tunnel
Still head is on and properly torqued down now. There's no sign of the screwdriver. I've tried fishing around with a long screwdriver with a magnet on. Will have to take the sump off again and hope I can get it from the bottom
1980 KZ1300 B2 Touring/A2
1980 CBX1000-A
1990 ZZ-R1100 C1
1980 CBX1000-A
1990 ZZ-R1100 C1
- strate6
Re: Big Bore Kit
12 years 1 month ago - 12 years 1 month ago
I cannot see why (like most) anyone would be concerned by the width of those liners ??????
No problem there at all ?????????
I have seen many water cooled liners like that run without any issue at all & no problems.
Ignore any alternative advice in my own experienced opinion.
Pete F
Pete F
Last edit: 12 years 1 month ago by strate6.
- KzFlames
- New Member
Re: Big Bore Kit
12 years 2 weeks ago
The article was written by Gert Roewer from Australia. He is obviously a talented machinist! Here is the link to the article:
www.dreadsbikersite.com/Z1300/1502_bigbore.htm
- KzFlames
- New Member
Re: Big Bore Kit
The article on the 1502 built using 750 pistons was written by Gert Roewer from Australia. He is obviously a talented machinist! Here is the link to the article:
- Mikez
- Elite Member
Re: Big Bore Kit
Has anyone ever gotten any dyno data on a bike that has had that done to it? I'm curious as to the difference it makes. Thanks!
- zed_thirteen
Re: Big Bore Kit
Hi guys,
I hooked up the battery today to run some compression tests after the 1370 re-bore. Was surprised by the results:
1 10 bar
2 9 bar
4 8.5 bar
4 8.4 bar
5 7.6 bar
6 10 bar
No carbs on, no exhausts on, all spark plugs removed.
Can it be normal to have this much difference between cylinders after a re-bore? Do I need to check again after It's been run in?
I had the head vacuum checked for cracks and pressure checked for valve seat leaks.
I would have thought all of that with new bores and new rings would have given me a much more even set of results.
Should I try with a little oil in each barrel?
1 10 bar
2 9 bar
4 8.5 bar
4 8.4 bar
5 7.6 bar
6 10 bar
1980 CBX1000-A
1990 ZZ-R1100 C1
1980 CBX1000-A
1990 ZZ-R1100 C1
Moderators: scotch
Time to create page: 0.165 seconds
