Big Bore Kit
- zed_thirteen
Re: Big Bore Kit
12 years 2 months ago
Got the head back from machine shop today - JTR Engines in Poole. Very pleased with their work
I had the head pressure checked for leaks/cracks between water jackets and the chambers. I also got the head vacuum checked to test the valves were sealing in their seats.
All good to go back on now.
1980 KZ1300 B2 Touring/A2
1980 CBX1000-A
1990 ZZ-R1100 C1
1980 CBX1000-A
1990 ZZ-R1100 C1
- Toddh
Re: Big Bore Kit
Did the machine shop deck the cylinder head?
If so, how much did they take off?
T.
T.
KZ1300 A-4 4TH 1300 IN 30 YEARS
KZ1000 D-3/ Z1R
ZX900 GPZ A-3
KZ750 E-1
K1200GT
CB750F 1978
KZ1000 D-3/ Z1R
ZX900 GPZ A-3
KZ750 E-1
K1200GT
CB750F 1978
- zed_thirteen
Re: Big Bore Kit
forgot to mention that. Yes, this time 4.5 thou was removed.
I did have it done a few years back but I can't find info on how much was removed.
1980 CBX1000-A
1990 ZZ-R1100 C1
1980 CBX1000-A
1990 ZZ-R1100 C1
- zed_thirteen
Re: Big Bore Kit
Do I need to use a special "running in" oil when I put this back together?
I've been watching "Fast 'n' Loud" and they managed to destroy cams in a newly built engine because they didn't use the correct running in oil.
My crank and cams are already run in. The only new components will be the rings pistons and wrist pins.
1980 CBX1000-A
1990 ZZ-R1100 C1
1980 CBX1000-A
1990 ZZ-R1100 C1
- strate6
Re: Big Bore Kit
12 years 2 months ago - 12 years 2 months ago
I always just use the same oil I would normally use after a rebuild/refurbishment.
No need to use any special type of oil for running in.
Its worth changing it between 500 & 1000 miles though just to be safe & get rid of any small metal particles floating around.
If you dont have a magnetic sump plug, them its well worth having one as it traps the small metal parts (if any there) & lets you see them when you drop the oil. Our bikes sump plug is the same size as a Subaru Impretza (much cheaper to buy !).
Pete F
UK
Pete F
UK
Last edit: 12 years 2 months ago by strate6.
- zed_thirteen
Re: Big Bore Kit
cheers Pete,
I normally use Halfrauds 10W/40 motorcycle oil as it's been recommended by several people
I also fitted a Subaru magnetic sump plug (your recommendation if I remember correctly)
1980 CBX1000-A
1990 ZZ-R1100 C1
1980 CBX1000-A
1990 ZZ-R1100 C1
Moderators: scotch
Time to create page: 0.167 seconds
